Author Topic: Alternator squeal after engine start  (Read 12456 times)
August 19, 2011, 06:27:14 am
92EcoDiesel Jetta
« on: August 19, 2011, 06:27:14 am »
Anyone get the alternator squeal after every engine start? I've tightened the belt and it still squeals but I don't want to tighten it anymore since I don't want to shorthen the life of the bearings. I've been taking current measurements and to my surprise, the squeal is not due to high amperage loading of the glow plugs but rather from the alternator surge (around 45 amps) charging the battery. I disconnected the glow plugs, started the engine and it still squealed while the ammeter indicated 45 amps! As the ammeter reading drops over approx 3 to 4 seconds, the squeal stops. I am trying to find a work around since it is annoying as hell!
Reply #1August 19, 2011, 08:59:49 am
Re: Alternator squeal after engine start
« Reply #1 on: August 19, 2011, 08:59:49 am »
buy a new belt. your old one is glazed. pullies may be also..
Reply #2August 19, 2011, 03:40:35 pm
92EcoDiesel Jetta
« Reply #2 on: August 19, 2011, 03:40:35 pm »
Belt has less than 1500 miles on it although it did squeal for a long time before I adjusted it so it is probably glazed and should be replaced. What are sources of new pulleys?
Reply #3August 19, 2011, 05:36:32 pm
« Reply #3 on: August 19, 2011, 05:36:32 pm »
Sometimes a little emery cloth on the pulleys can help.  You don't really want a rough surface though as it will wear the belts prematurely.
Also make sure you really do have the correct belt - VW belts are all metric so just buying one that 'looks' right doesn't necessarily mean it is actually the correct taper.  Metric V-belts have a different taper than SAE V-belts.  They're close enough to seem like they fit but they don't really work right and will slip, etc.
Reply #4August 23, 2011, 07:30:32 am
larry104
  • 200
« Reply #4 on: August 23, 2011, 07:30:32 am »
I had the same problem with the same model/year car. It's not the belt or the pulleys. I replaced the belt multiple times as well as the idler and alternator pulleys. It's the design. Tightening the idler reduces the wrap angle on the alternator pulley, which make the belt slip more. The belt glazes, overheats, then snaps.
Here's how I fixed the squeal...
http://www.vwdiesel.net/forum/index.php?topic=29090.0
My setup has 3,600 miles so far and NO squeal. I'm thinking of making a kit for those who don't have access to machine tools.
Reply #5August 23, 2011, 11:11:46 am
« Reply #5 on: August 23, 2011, 11:11:46 am »
do you have a/c?
that small belt is the problem if you are running a/c.. look at how thin it is..
im running non a/c, and my belt has a smaller bite (wrap angle) on the pulley, and slips. but thats because i have an SAE belt on a german car..
Reply #6August 23, 2011, 11:55:28 am
wdkingery
  • 494
« Reply #6 on: August 23, 2011, 11:55:28 am »
I get a squeal sometimes. UT its not belt. It's bearing some way. Someone said might be timin belt pulley.
My damn a/c. Compressor won't stay tight for the life of me!
Reply #7August 23, 2011, 12:36:37 pm
« Reply #7 on: August 23, 2011, 12:36:37 pm »
you really need to make sure its not the timing belt tensioner. when they start talking to you, they are saying
"HEY, CHANGE ME BEFORE I WRECK YOUR ENGINE!!"
when that tensioner seizes up, it starts melting the backing off the belt, then when it wears thru enough, the belt snaps, and your engine is trashed..
CHANGE IT!! or atleast make sure its not the culprit of the noise before it locks up and you get the clash of death..
Reply #8August 23, 2011, 04:06:32 pm
larry104
  • 200
« Reply #8 on: August 23, 2011, 04:06:32 pm »
do you have a/c?
Yes, car has A/C. I tried three different belts, including the Dayco part number that's on there now (best of the bunch). The Dayco, without the additional idler, needed adjustment within a couple weeks and lasted only a few months. The current setup uses the Dayco belt as well. I've not adjusted it.  The belt is still tight and shows no sign of distress after 3600 miles, which is since mid-May.  I'm fairly sure the problem is fixed.
Reply #9August 24, 2011, 08:21:56 pm
  • 3468
    • McScrubbins Body Wash
« Reply #9 on: August 24, 2011, 08:21:56 pm »
I can rarely get my alternator pulley to stop squeeling and I can't find a new pulley for any reasonable price so i take the pulley off about once ever 2 years and completely sand it down with 40 or 60 grit inside.
new belts also help. V-belts are just a poor design. I'm tempted to run a chain. - would also sound AWESOME
Reply #10August 27, 2011, 09:33:50 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
« Reply #10 on: August 27, 2011, 09:33:50 pm »
to be honest you think the germans would have been smart enough to not use v belts and mechanical tensioners, they are the worst f**king  thing to ever use in a vehicle. ive gone through 3 belts this month. the only true way to get rid of this problem would be to either swap to serp or drop in an aaz. it just happened to me again tonight coming home from the drive in, if i dont sit there for 5 min untill my tach starts working, the belt snaps, u can smell burning rubber. so amazingly aggravating that it makes me want to put a brick on the pedal and run it off a cliff. it helps if the pullies line up, usually have to find a old alternator to find shims because they stopped including them with new alts.
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #11August 27, 2011, 10:19:43 pm
nathan_b
  • 361
« Reply #11 on: August 27, 2011, 10:19:43 pm »
way back when the 36hp beetle land speed record was set by a guy running a supercharger off a bicycle chain...
never failed and he was turning like 7krpm. lol
Reply #12August 28, 2011, 05:54:04 am
larry104
  • 200
« Reply #12 on: August 28, 2011, 05:54:04 am »
Cold start of my Ecodiesel...
http://www.youtube.com/watch?v=ZHVXbKD5IPk
...No squeal.
Reply #13August 28, 2011, 01:00:23 pm
Mark(The Miser)UK
  • 1557
« Reply #13 on: August 28, 2011, 01:00:23 pm »
Or buy a Quantum. In about 18 years of driving them, I don't remember changing an alt belt. An alt or 2 yes! Maybe it's an A/c thing. Never ever seen an A/C equipped Q in the UK, although I do have a set from USA in the cupboard ;D
Mark-The-Miser-UK
Reply #14August 28, 2011, 06:11:00 pm
92EcoDiesel Jetta
« Reply #14 on: August 28, 2011, 06:11:00 pm »
...No squeal.
Nice! Is adding the roller tensioner the only change? Did you keep the stock tensioner?
