Author Topic: Injector cleaner  (Read 4937 times)
September 18, 2011, 03:23:18 pm
Mike Robinson
  • 4
Injector cleaner
« on: September 18, 2011, 03:23:18 pm »
Does anyone have a prefered injector cleaner that you add to the fuel.  I add standardyne, but every oil change it sure does run well after I run some liquid moly diesel purge through it.
As this is difficult to come by, is there a more generic product out there that is recommended?
Mike
AAZ
Reply #1September 18, 2011, 11:10:47 pm
mystery3
  • 774
Re: Injector cleaner
« Reply #1 on: September 18, 2011, 11:10:47 pm »
The Lubro moly stuff is all I ever use in my various german cars, why is it hard to get in canada? Can your local parts shop not special order it for you?
Reply #2September 19, 2011, 04:14:33 am
DJPyro
  • 66
« Reply #2 on: September 19, 2011, 04:14:33 am »
I use "DieselKleen", available at CT: http://www.canadiantire.ca/AST/browse/4/Auto/3/AutoFluidsChemicals/DieselAdditives/PRDOVR~0380766P/Diesel+Kleen+with+Cetane+Boost.jsp?locale=en
It was recommended to me by the diesel mechanic I worked with at a GM dealership, it's what he runs in his Duramax. I add some every few tanks, and a smaller amount every tank in the winter. Seems to help, but I do notice my mileage goes down a bit if I use it every tank in the warmer weather.
Reply #3September 19, 2011, 11:55:38 am
« Reply #3 on: September 19, 2011, 11:55:38 am »
Mike
AAZ
its "Stanadyne"..
and i run straight 2 cycle oil in my diesel all the time, and i run some ATF occasionally to clean the injectors.
Reply #4September 19, 2011, 03:03:55 pm
wdkingery
  • 494
« Reply #4 on: September 19, 2011, 03:03:55 pm »
I have an injector that is tickin, particularly after higher speed runs.
someone mentioned to me that the injector is breaking early, and advancing the timing considerably.
anyone got any opinions on this?
i chased thru my oiling system to determine no fault found, and eventually added a healthy dose of Lucas fuel additive, and it went away, but a high speed on the way to school just now brought it back.
i had stopped waxin until my car stabilizes a bit (was gonna add wax tonight for the first time in a while)
i don't wanna take that injector out, as i had to tighten it to way over 100 ft/lbs to get it to stay in for some reason.. what damage will this cause?
i cannot wax thru the winter, so i need to know what i'm up against.
Reply #5September 20, 2011, 02:47:30 am
Mark(The Miser)UK
  • 1557
« Reply #5 on: September 20, 2011, 02:47:30 am »
Could be opening early.
Can you elaborate  thre highlighted comment?
Are you saying ther injector kept unscrewing, or were you struggling to get the heatshield to seal? Damage could be done to the head. A correctly distorted heatshield should work with 30lb ft.  Are you sure it's not injector body leak, or even diesel returns leaking?
I think the injector needs to come out, and checked...
Mark-The-Miser-UK
Reply #6September 20, 2011, 06:34:02 am
wdkingery
  • 494
« Reply #6 on: September 20, 2011, 06:34:02 am »
Really like it would begin to smoke from the threads where it was falling out.. Each time I would tighten it more and it would just keep falling out. Eventually I tightened the *** out of it and it stayed. I was quite sure I was gonna snap it clean off, or pull the threads out (or as I learned later, break a chunk of the head iff). But none of that happened. So id like it leave it if I can. It ain't ticked since yesterday
Reply #7September 20, 2011, 11:14:12 am
« Reply #7 on: September 20, 2011, 11:14:12 am »
dumping stuff in the engine oil will NEVER have ANY effect on an injector..
you tightened the injector body to 100 ft lbs, or the injector into the head at 100 ft lbs?
you may never get it back out in one piece if you tightened it in the head that tight..
Reply #8September 20, 2011, 11:15:58 am
« Reply #8 on: September 20, 2011, 11:15:58 am »
but it is ticking, and it needs to be fixed.. not gonna just fix its self, no matter what you dump in your tank. once the nozzle is compromised, the injector needs a full rebuild..
Reply #9September 20, 2011, 02:01:21 pm
Mark(The Miser)UK
  • 1557
« Reply #9 on: September 20, 2011, 02:01:21 pm »
That's quite common, especially when your keys are hung up and you're inside the house ;D
I have never heard of an inector unscrewing itself, seeing as the fuel line nut would need to be loose. :-\. The fact that it's noisy enough to be heard above a naturally noisy engine, and chosen, it must be significant.
I feel my leg being pulled  ;D
Mark-The-Miser-UK
Reply #10September 20, 2011, 07:49:28 pm
wdkingery
  • 494
« Reply #10 on: September 20, 2011, 07:49:28 pm »
Hahahaha no really as it did! The injector really only has to back out a tiny bit to begin smoking.
Well, anyway, the tickin has subsided considerably. It does tick sometimes, but not nearly as much as it did that day.
I will let you know.
(it really did fall out a few times!)
Reply #11September 21, 2011, 02:23:14 pm
  • Online
« Reply #11 on: September 21, 2011, 02:23:14 pm »
I bet the sealing surface is corroded and isn't sealing good.
Reply #12September 21, 2011, 06:37:00 pm
nathan_b
  • 361
« Reply #12 on: September 21, 2011, 06:37:00 pm »
did you use NEW heat shields?
Reply #13September 21, 2011, 06:54:37 pm
« Reply #13 on: September 21, 2011, 06:54:37 pm »
start the car and get it running till warm, take the fuel lines off the filter and put them in a jug of auto trans fluid straight. and run the jug dry. before it runs out completely let the engine sit for a few hours then hook your feul line back up and run it as normal.
ATF is a very very good cleanser.
Reply #14September 22, 2011, 08:56:31 am
« Reply #14 on: September 22, 2011, 08:56:31 am »
of course it is, its LOADED with different detergents..
