Author Topic: Turbo Oil Supply Line Sprung a leak. Get new? Make New? Fix Leak? Get Used?  (Read 4686 times)
April 23, 2010, 03:28:20 pm
Ziptar
  • 565
  :o  >:(  :(  :'(
The Oil Supply Line for the Turbo on my Eco sprung a leak. Looks to have rusted under the rubber of the clamp that holds it to the manifold.
I can't find a part number, are they still available new? Any one happen to know what fittings I'd need to make one out of brake line? Is it worth while to fix it or braze it? Or is it one of those one it starts to go it's gone kind of things. I'll put a post in the FS/FT but, I am guessing the same thing may happen with it eventually too.
Thanks.
« Last Edit: April 23, 2010, 03:44:32 pm by Ziptar »
Reply #1April 23, 2010, 04:14:33 pm
u can probably take ur old line in to anywhere that makes hydraulic hose and they'll fix you right up
Reply #2April 23, 2010, 04:15:41 pm
GEE-BEE
  • 1604
AAZ MODEL 028-145-771-D 90.00 LIST
70.00 Is what i paid, Includes new banjo bolt and washers
local VW dealer
GB
« Last Edit: April 24, 2010, 08:51:32 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3April 23, 2010, 04:28:58 pm
Ziptar
  • 565
70.00 Is what i paid, Includes new banjo bolt's and washers
local VW dealer
GB
Thanks GEE-BEE! 1stvwparts lists it for $66.99!
Reply #4April 24, 2010, 06:44:19 am
Ziptar
  • 565
The mk2 supply line is not connected using banjo fittings and bolts.
I would reuse the two nuts, get the appropriate diameter brake line and two compression ferules to fit it and bend it up.  It would likely cost less than $10 and take less than an hour all said and done.
Thanks Andrew!
Heck it's worth a shot, for an hour and $10. Using the compression ferules I guess that means the ends don't need to be flared.
I'll go by NAPA see what they've got in a little bit. I am just about to start rebuilding one of my VE pumps this morning (my first attempt). I've got myself all psyched up for that at the moment.  :D So I'll run down when I take a break.
If all goes well, rebuilt pump and new oil line install next week end!
Reply #5April 24, 2010, 08:53:52 am
GEE-BEE
  • 1604
Mine has a banjo bolt at the filter housing and a female swivel at the turbo...
I installed new clamps also while I had it off......
1.9 aaz
want a pic, email me at [email protected]
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #6April 24, 2010, 07:12:05 pm
  • 2932
NAPA has the right kind of ferrels for 5/16" tubing,..
 it is 5/16" ,.. 8mm right?,.........................
 I thought I bought some seperately, probably did but can't find the reciept.
Looks like my ferrel came with the 1/8"NPT X 5/16" compression fitting I bought for the VNT Rabbit oil supply line :NAPA# 7205X5 might help you get close to finding a ferrel.
I got a nut and ferrel for turbo end of the line, from the dealership.
 Ferrel part number is:
N 0208292 $3.97
Reply #7April 26, 2010, 10:27:03 pm
Quantum TD
  • 1195
1.9 aaz
GB
Pull yer head out.
This is for a 1.6TD, not a 1.9TD. The 1.6 oil return line ties into the oil pan. The 1.9 AAZ returns into the back of the block. Two completely different designs.
Reply #8April 28, 2010, 09:21:12 am
arb
That's what I did. Still no problems with my supply line.  The SAE line flaired nicely in the metric nut.
« Last Edit: April 28, 2010, 09:23:08 am by arb »
Reply #9April 28, 2010, 04:26:18 pm
GEE-BEE
  • 1604
Hey Quantam, trying reading first before you go mouthing off...
Are you here to help ?
GB
Giles Pump OHC
MK1 JETTA DASH
