vaccum pump install problems
Topic: vaccum pump install problems (Read 1932 times)
May 03, 2010, 04:15:01 pm
morgoon
May 03, 2010, 04:15:01 pm »
Hello all
I pulled the vaccum pump on my 84 1.6na to prime it, and I can't seem to get it to line up with the oil pump again
I can get the gears to mesh, but it won't drop down the rest of the way, I searched a while
Just thought I would ask here for tip or trick
I hope this is the right section to post in
Regards
May 03, 2010, 04:27:21 pm
Re: vaccum pump install problems
May 03, 2010, 04:27:21 pm »
I would try pushing down on the vac pump and turning the engine over by hand. Should be 19mm socket if it is the 12pt bolt.
Round 2
May 03, 2010, 05:54:16 pm
morgoon
May 03, 2010, 05:54:16 pm »
Thanks guys
I chilled out for a bit, took my time and worked it a little twist at a time, in, out, in, out, etc...then boom it dropped in
Sure appreciate your time
