Author Topic: Alternator belt 1.9 AAZ ( non - A/C ) Serp setup  (Read 1870 times)
April 27, 2010, 03:16:43 pm
GEE-BEE
  • 1604
« on: April 27, 2010, 03:16:43 pm »
Booked called for a 6PK1045 too short
Tried a 6PK1055 too short also
I fitted a 6PK1080 and it was perfect.
Iam not sure if it matters if you have a clutch pulley or not  as they do look the same O.D.
maybe the parts book calls for the plunger type alternator mount , versus the serptine setup
I have seen motors with and without this alternator mount assy.
I have both types, and installed a serp assy.
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
