Author Topic: I need a head asap  (Read 2947 times)
April 26, 2010, 08:59:23 pm
jpedro
  • 137
I need a head asap
« on: April 26, 2010, 08:59:23 pm »
So my car blew a timming belt the other day. I pulled the head off and everthing, #1 cylinder has a bent exhaust valve. i would rather get a 2nd hand brand new head rather then waste time rebuilding mine, and i need a vehicle for work and what not, i dont like relying on people for rides. but to the point of the story im gunna need instructions for timming the engine once i get the new head all on tourque specs for the magor components, and if there is one of the hydraulic covers over the springs that moves freely but i cannt get it out how do i go about doing so? the others slipped out when i flipped the head upside down. mainly need help doing the timming part the rest can be figured out fairly simple so all the help i can get is muchly appreciated
thanks Jpedro
1990 VW Jetta 1.6L TD 235000kms Custom cold air intake and Custom 3" straight pipe
1992 Ford F250 7.3L IDI custom everything you can possibly think of. ( my braging rights are live with this toy)
Reply #1April 26, 2010, 09:00:51 pm
jpedro
  • 137
Re: I need a head asap
« Reply #1 on: April 26, 2010, 09:00:51 pm »
oh and i am located in Terrace BC Canada so someone fairly close with a head would be a bonus for shipping costs.
Reply #2April 26, 2010, 09:03:08 pm
« Reply #2 on: April 26, 2010, 09:03:08 pm »
The FAQ has all kinds of great info, including how to set the timing... pictures and everything!  ;)
Reply #3April 27, 2010, 09:46:51 am
jpedro
  • 137
« Reply #3 on: April 27, 2010, 09:46:51 am »
no one? i couldnt find anything in the FAQ section on how to time my car after blowing a timming belt
Reply #4April 27, 2010, 10:17:07 am
« Reply #4 on: April 27, 2010, 10:17:07 am »
5th section down in the main FAQ thread:
http://www.vwdiesel.net/forum/index.php?topic=16687.msg118139#msg118139
AAZ heads are pretty rare these days... it may take a while to find a good one so you may have to be a bit patient.
Reply #5April 27, 2010, 10:27:08 am
« Reply #5 on: April 27, 2010, 10:27:08 am »
i would look into buying an exhaust valve and lifter if thats all thats visibly wrong. if it didnt mangle the head or the valve seat then you should be good to go.
Reply #6April 27, 2010, 02:30:04 pm
jpedro
  • 137
« Reply #6 on: April 27, 2010, 02:30:04 pm »
i just ordered a intake and exhaust valve for the one hole that got messed up and i should be good to go:) parts will all be in friday and ill be up all night mending it now. thanks for the speedy help if i need more ill be back.
Reply #7April 27, 2010, 02:36:09 pm
« Reply #7 on: April 27, 2010, 02:36:09 pm »
The tricky bit will be if one or more valve guides got messed up in the process... pretty much need a machine shop to replace 'em.
Reply #8April 27, 2010, 05:59:49 pm
GEE-BEE
  • 1604
« Reply #8 on: April 27, 2010, 05:59:49 pm »
AAZ, I have a found a few new ones from time to time , complete assy's ( new )275.00 to 300.00 in Europe
I sold my last new one complete with cover for 550.00
I try to keep a spare around
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #9April 27, 2010, 07:58:40 pm
Kantdrivefast
  • 196
« Reply #9 on: April 27, 2010, 07:58:40 pm »
mechanical or hydraulic?
Reply #10April 27, 2010, 10:25:29 pm
« Reply #10 on: April 27, 2010, 10:25:29 pm »
I think the AAZ only ever came in hydraulic?
Reply #11April 27, 2010, 10:36:24 pm
« Reply #11 on: April 27, 2010, 10:36:24 pm »
Yup... 'sfar as I know... at least in North America. ;)
Reply #12April 28, 2010, 09:08:21 am
Kantdrivefast
  • 196
« Reply #12 on: April 28, 2010, 09:08:21 am »
From his sig line:
1990 VW Jetta 1.6L TD 235000kms Custom cold air intake and Custom 3" straight pipe[quote/]
So we can assume its hydraulic.
Reply #13April 28, 2010, 09:18:55 am
« Reply #13 on: April 28, 2010, 09:18:55 am »
isnt it safe to assume that if the old valve comes out nicely, and the new one goes back in and doesnt move around, then the valve guides are alright? just re-seal them and go? its gonna be pretty appearent if the valve guides are messed up wont it?
Reply #14April 28, 2010, 06:43:00 pm
jpedro
  • 137
« Reply #14 on: April 28, 2010, 06:43:00 pm »
i got my head all rebuilt whats the tourque on the head bolts and sequence?
also tourque for the intake and exhaust manifold
