Author Topic: how do I block the 2nd oil drain in a hydro head?  (Read 2026 times)
January 22, 2008, 05:39:49 pm
turbosuzi
« on: January 22, 2008, 05:39:49 pm »
I am going to use a hydro head on a 1.6 na but I dont know how to plug the smaller oil return inthe head.
Reply #1January 22, 2008, 06:06:49 pm
« Reply #1 on: January 22, 2008, 06:06:49 pm »
tap and plug it
Reply #2January 22, 2008, 06:31:09 pm
turbosuzi
« Reply #2 on: January 22, 2008, 06:31:09 pm »
Is there a way to with out having to tap it iand plug it because I will want to put the head back on the hydro block that is going to get new bearings in it. I have seen a thread on a similar subject that used a piece of rubber to cover a hole.
Reply #3January 22, 2008, 06:48:34 pm
« Reply #3 on: January 22, 2008, 06:48:34 pm »
i wrote up what all the different combos need as far as plugging goes do search on metal headgaskets under my name,  u can plug the extra drain hole and still use that head on a hydro block, it won't make any difference.  and if u are just putting a hydro head on a 1.6 solid block with a solid lifter hg, u could actually most likely get away with siliconing the hole shut since theres no real pressures on it.
