convert my ecodiesel to true TD
Topic: convert my ecodiesel to true TD (Read 2030 times)
January 22, 2008, 03:37:48 pm
greenbert
User+
January 22, 2008, 03:37:48 pm »
Do all I need is a LDA or injector pump from a TD jetta? if i upgraded the turbo what turbo would you suggest? What all would I need to make this happen?
1991 Volkswagen jetta ecodiesel (stock)
January 22, 2008, 05:08:56 pm
greenbert
User+
January 22, 2008, 05:08:56 pm »
I will be removing the cat soon. I really just want the car to run a little bit better, like a TD golf or jetta. And do you think i'll see much of a difference in my mpg?
January 22, 2008, 09:31:06 pm
Diesel Fumes
January 22, 2008, 09:31:06 pm »
Don't bother with a pump swap. Just drive it as is, remove the cat, straight pipe it maybe, turn the boost up a bit, it will be a fun car and faster than any stock MKII TD. When the pump gives out, have it rebuilt by Giles.
