Author Topic: torque spec for injectors?  (Read 17309 times)
January 11, 2008, 06:25:23 am
giulianot
  • 146
« on: January 11, 2008, 06:25:23 am »
when reinstalling injectors on an aaz head is there a specific torque spec or do you just tighten till all the return lines are in line?
1990 cabriolet 1.9 aaz, kkk 24/26,  Giles pump, big  2.5" intercooler,  3 " P.P. downpipe
Reply #1January 11, 2008, 08:33:47 am
« Reply #1 on: January 11, 2008, 08:33:47 am »
1/2 impact gun and rattle the hell outta them!!!!   :D
That's a joke BTW, dont want anyone thinking I was serious there  :roll:
Andrew's advice is spot on.
Reply #2January 11, 2008, 02:51:11 pm
giulianot
  • 146
« Reply #2 on: January 11, 2008, 02:51:11 pm »
thankyou will torque to 52 ft-lbs :D
Reply #3January 14, 2008, 06:00:41 am
saurkraut
  • 904
« Reply #3 on: January 14, 2008, 06:00:41 am »
Torqueing to 52 ft/lbs scares the heck out of me, and I'm fearless.  So thats how scarry it is.
I lube the hole, and Injector with copper antisieze, then torque to 30 ft/lbs.
The 52 ft/lbs spec is probably a 'dry' torque.  I back it off quite a bit due to the liberal use of copper antisieze, but haven't had any issues yet, like busted injector bosses, or leaking injectors, stuck injectors, or stuck heat shields.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #4January 14, 2008, 06:07:38 am
« Reply #4 on: January 14, 2008, 06:07:38 am »
Quote from: "saurkraut"
but who wouldn't use some sort of anti-seize on the injector threads??? seems foolish...painfully remove gunked up injectors, and re-insert them to get gunked up and hard to remove later down the road... i LOVE the tdi design!!!!  8)  way easier to remove the injectors.
Reply #5January 14, 2008, 06:53:12 am
saurkraut
  • 904
« Reply #5 on: January 14, 2008, 06:53:12 am »
My point exactly with respect to the OEM torque spec.
I suspect the antisieze drastically alters the thread friction during torqueing.
Taking 20 lbs off is my 'fly by the seat of my pants' guess on how much to reduce the torque.
I've done it for years with only positice results.
I think its important to use a torque wrench as well, and to specifically grind the heck out of a socket and extension to fit behind the LDA.
The injector hole behind the LDA is the one I always see with a stuck heat shield on other folk's engines.  That one is always tough to get to with standard tools, And I think tightening by 'feel' never gets it fully steated.  This results in leakage, wich gets a big gob of carbon built up around the injector tip and heat shield.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #6January 14, 2008, 08:00:07 am
« Reply #6 on: January 14, 2008, 08:00:07 am »
I don't use antisieze so I torque to spec (52)
Reply #7January 19, 2008, 12:42:21 pm
« Reply #7 on: January 19, 2008, 12:42:21 pm »
When I was changing my head I had to swap the injectors over to the new head. I had a 18inch breaker bar and a friend to hold the head down (it was off the engine) and I could barely get one of the injectors loose and the I just turned it 'till it came out, no back and forth or WD-40. I don't think it cracked the head, but I don't care either. Then I put 'em in the new head dry and torqued on 'em whatever way was handiest, no problems yet.
Reply #8January 19, 2008, 10:53:07 pm
Black Smokin' Diesel
  • 656
« Reply #8 on: January 19, 2008, 10:53:07 pm »
I used anti-seize paste and torqued them to 50lb. No problem at all.
Reply #9January 21, 2008, 12:54:28 pm
« Reply #9 on: January 21, 2008, 12:54:28 pm »
yeah, well the only reason I didn't push towards the head is 'cause I didn't know it was better :oops: definitly good advice though.
Reply #10January 21, 2008, 01:02:34 pm
blkboostedtruck
  • 1535
« Reply #10 on: January 21, 2008, 01:02:34 pm »
also work it in and out! i still busted one of my bosses on my head!
the antisieze clunks up and binds and will break a boss!
important to clean all old antisieze out before reinstalling! i think thats where i made the mistake when i broke my boss?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #11January 21, 2008, 01:19:20 pm
saurkraut
  • 904
« Reply #11 on: January 21, 2008, 01:19:20 pm »
The copper antisieze doesn't wad up like the silver stuff does under heat.
I think thats why they copper coat the exhaust stud nuts.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #12January 21, 2008, 01:28:52 pm
blkboostedtruck
  • 1535
« Reply #12 on: January 21, 2008, 01:28:52 pm »
yea i noticed that too! all i use is the copper now!
i have a couple can of silver that are dried up but the copper don't that bad?
Duane
'66 variant 1500S
