Author Topic: Cam shaft pulley: really need help!!!  (Read 2645 times)
September 26, 2006, 01:54:34 pm
jantd
  • 38
« on: September 26, 2006, 01:54:34 pm »
Hi guys,
I once read a text about the cam pulley, but can't find it.  Here's the question: I've changed my timing belt, and need to retighten the cam pulley. The engine is a 1.9 td aaz, and the shaft has no woodruff key, so if it slips, the engine is seriously damaged. My Haynes says you tighten with 4.5 daN.M, but I remember that this is too low,and I heard about slipped pulleys if only 4.5 was applied.
This really worries me, so is there someone who knows THE method to mount this pulley on the Cam shaft, so I have a peace of mind? I'd really appreciate.
Thanks a million..
Best regards,Jan
Reply #1September 26, 2006, 08:25:26 pm
addautomotive
« Reply #1 on: September 26, 2006, 08:25:26 pm »
Lol... "rewhap" is my favorite new word!
Reply #2September 26, 2006, 09:08:14 pm
macsdub
  • 165
« Reply #2 on: September 26, 2006, 09:08:14 pm »
yea i like that too rewhap
yea do all that,and use a little scotch brite(like on kitchen sponges on 1 side)
brakecleen and all that,and do the wapping trick
actually chevy(actually gm in general i think) calls setting the thrust bearings "tonking" or "tonk"
like when you tighten up the caps,go to like the 1st stage+ tonk the crank back+forth to "set" the thrust bearings in place nicely
i tonked my tdi(i used a plastic mallet)
hit it,dont kill it :wink:
most of the time this is hilfolk'r... ive forgotten my password
Reply #3September 29, 2006, 12:06:13 pm
jantd
  • 38
« Reply #3 on: September 29, 2006, 12:06:13 pm »
hi guys,
thanks a lot for all your advice, really great to have your help!!
so I tightened with 45ftlbs, hit the bolt as well as i could (the gas filter is a bit in the way), and in my case the bolt didn't turn anymore below 45ftlbs, I guess it was right from the first time..i must say that 45 ftlbs didn't feel like a big torque..
i turned twice the crank, and seems alright..
do you think it's a good idea to loosen the bolt now and put loctite on it, or would it be too hard to loosen?
i still have a 0.15 mm difference between both sides of the camlocktool,should i worry?
thanks,Jan
Reply #4September 29, 2006, 05:32:56 pm
QuickTD
  • 1156
« Reply #4 on: September 29, 2006, 05:32:56 pm »
I've always just tightened them to the recommended torque, no hammering, no locktite and no problems. Tapered fits grip like grim death. If you hang around a machine shop for any length of time you'll soon notice that most cutting tools are retained by tapered fits, they often transmit 20hp or more without slip. A bolted tapered joint is absolutely 100% reliable, I wouldn't worry about it.
Reply #5September 29, 2006, 07:52:15 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #5 on: September 29, 2006, 07:52:15 pm »
Newer bobcats have a taper fit on the front pivot. I impact gun the hell out of them (800 ft/lbs) then I use my adjusting tool (16lb hammer with a 1ft handle). Then I usually get 1/3 of a turn.  Usually I have to do this 2-3 times till I cant get the bolt to turn anymore.
Not as important as a cam bolt but it gets alot of abuse and thats the only way I can make it so I dont have to go out and do it again.
The shock of the hammer strike just helps the taper fit better.
heh...I want to dyno my impact gun.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
