TB tensioner, up or down?
Topic: TB tensioner, up or down? (Read 2057 times)
December 06, 2009, 03:20:13 pm
truckinwagen
December 06, 2009, 03:20:13 pm »
does it matter which way the TB tensioner is turned for belt tensioning?
do I pull it up, or push it down?
thanks,
-Owen
83 Opel Kadett Diesel
December 06, 2009, 04:03:59 pm
cyrus #1
Re: TB tensioner, up or down?
December 06, 2009, 04:03:59 pm »
I turn mine clockwise, or up, if you will. It will give more of a wrap on the cam sprocket and also make tightening the nut easier. If you go down it will tend to want to slacken on you as you tighten the nut.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
December 06, 2009, 04:08:55 pm
December 06, 2009, 04:08:55 pm »
All vw tensions go clockwise , until the MK 4 2.0 and maybe the 1.8 gassers. They will have and arrow if they go counterclockwise. otherwise always "up"
December 06, 2009, 04:11:03 pm
truckinwagen
December 06, 2009, 04:11:03 pm »
thats what I did, just wanted to confirm
thanks!
-Owen
