Author Topic: '91 Jetta 1.6 na coolant temp gauge not working  (Read 2111 times)
December 09, 2009, 05:26:45 am
mx597turbo
  • 7
« on: December 09, 2009, 05:26:45 am »
I just bought the car. Everything else on the cluster works. But the coolant gauge didn't move at all, it stayed all the way on cold. Does this sound like a bad coolant sensor or problem with the gauge?
Can I use a multimeter to check if the sensor is working? If so, what should the reading be is the sensor is properly functioning?
