Author Topic: 200hp in Azz enigen  (Read 7217 times)
August 18, 2006, 03:36:30 am
ISBjornen
  • 36
200hp in Azz enigen
« on: August 18, 2006, 03:36:30 am »
Hello every body.
i have a Mk3 with the 1,9l Azz enigen.
wath do i have to do to gett 200hp?
cost?
i all redy have a schwitzer S1bg turbo, alu intercooler.
Kristensen
Reply #1August 18, 2006, 12:50:31 pm
200hp in Azz enigen
« Reply #1 on: August 18, 2006, 12:50:31 pm »
What is the current state of the motor? has it been rebuilt recently?  Most on this forum will agree that a good base motor should be in excellent condition before attempting to push 200 hp.  The boost required to get you 200 hp may seep past the rings and cause some problems later on (extra pressurized oil or whatnot)
If you have that all taken care of, maybe you should consider sending your pump to Giles for a performance upgrade.
Reply #2August 18, 2006, 04:05:57 pm
Audi80
200hp in Azz enigen
« Reply #2 on: August 18, 2006, 04:05:57 pm »
Quote from: jtanguay
Or send to Finland which is much closer to Sweden. HP-Diesel, PP-diesel or Mynä-diesel will make a pump you need. But I´d bet there is a good pump specialist in Sweden too.
Reply #3August 19, 2006, 04:34:26 pm
ISBjornen
  • 36
200hp in Azz enigen
« Reply #3 on: August 19, 2006, 04:34:26 pm »
i have now sent my pump for upgrade to o 12mm head.
Kristensen
Reply #4August 20, 2006, 02:29:04 am
Mark(The Miser)UK
  • 1557
200hp in Azz enigen
« Reply #4 on: August 20, 2006, 02:29:04 am »
What does a 200hp diesel sound like? Can it ever be made to sound throaty?  :mrgreen:
Mark-The-Miser-UK
Reply #5August 20, 2006, 06:40:24 pm
hillfolk'r
  • 1532
200hp in Azz enigen
« Reply #5 on: August 20, 2006, 06:40:24 pm »
um,try this :wink:  its a tdi-m though,complete with a slipping centerforce d/f clutch,i dont think its 200 hp,but it does lo/mid 14s on street tires daily driven
http://s63.photobucket.com/albums/h127/hillfolker/
Throttle cables ftw
Reply #6August 21, 2006, 11:31:03 pm
ISBjornen
  • 36
200hp in Azz enigen
« Reply #6 on: August 21, 2006, 11:31:03 pm »
im hoping to do a high 12 om 402m 1/4mile. there is a guy i sweden how have done a low 13sek whit 11mm injector head.
I have now orderd a clutch, sachs it can take 450Nm.
A turbo is on its way to.
Kristensen
Reply #7August 22, 2006, 11:42:10 pm
ISBjornen
  • 36
200hp in Azz enigen
« Reply #7 on: August 22, 2006, 11:42:10 pm »
now a have got the pump and turbo. i monted it last night. this project is going faster then i thought.
I made a plate betwen the enigen exhaust and the turbo, monted the intercooer and the pipes to it
Pic´s
turbo in place
electronik inside. (pic taken before the turbo was installd
BBCode, för forum:
Last winter i went of the road and have been driving whit a broken bumper ever sins. now Im making a new one
Intercooler, Im going to ha dubbel saab 9000 turbo IC but now there is only one
Enigen
Enigen and pipes to intercooler
Turbo and airfilter, the filter is going to be moved later to o cooler place
Modification to the air intake, the egr valve is missing now
Intercooler pipe
Intercooler pipe behind the right headlight
Front maunted intercooler
This pipe also goes to the intercooler
Boost ant oil presure
Interier
extra fuel pump.
The car
Exhaust pipe
My assosiet
the sky last night
I hope you understand
Today i going for a test ride.
Kristensen
Reply #8August 23, 2006, 06:46:44 pm
RAMMSTEIN
  • 331
200hp in Azz enigen
« Reply #8 on: August 23, 2006, 06:46:44 pm »
Isn't a mkIII a bit heavy for maximum performance?
Nice project though! :D
Rammstein
In abscence of light, darkness prevails.
Reply #9August 23, 2006, 10:59:41 pm
ISBjornen
  • 36
200hp in Azz enigen
« Reply #9 on: August 23, 2006, 10:59:41 pm »
Its not so hewy, the upcoming winther Im puting it om a diet.
I will install a cage and nwe suspensions.
I tock i test ride last night and its worse then it was before the modification.
the bosst is 0,5bar upp to 4000rpm the it rices to 1,8bar.
how do i convert bar til psi?
Kristensen
Reply #10August 23, 2006, 11:45:01 pm
Audi80
200hp in Azz enigen
« Reply #10 on: August 23, 2006, 11:45:01 pm »
1bar=14,7psi
Reply #11August 24, 2006, 11:46:00 am
Mark(The Miser)UK
  • 1557
200hp in Azz enigen
« Reply #11 on: August 24, 2006, 11:46:00 am »
Quote from: hillfolk'r
Thanks
Do people still use those fish-tail exhausts? :mrgreen:
Mark-The-Miser-UK
Reply #12August 24, 2006, 03:40:48 pm
SMOKEYDUB
  • 630
200hp in Azz enigen
« Reply #12 on: August 24, 2006, 03:40:48 pm »
check your wastegate and what size is your turbine wheel? not enough fuel?
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #13August 31, 2006, 06:05:01 am
ISBjornen
  • 36
200hp in Azz enigen
« Reply #13 on: August 31, 2006, 06:05:01 am »
ther is fuel, the turbin in okey, ther is no leak in the intake.
Kristensen
Reply #14August 31, 2006, 07:54:11 am
200hp in Azz enigen
« Reply #14 on: August 31, 2006, 07:54:11 am »
oooo you should get an oil temp gauge as well.   It will help determine how long you should let your car cool down after a hard run.  :)
