Author Topic: Engine meltdown warning...  (Read 2353 times)
September 02, 2006, 09:02:21 am
Mark(The Miser)UK
  • 1557
« on: September 02, 2006, 09:02:21 am »
On another forum someone wanted an alarm for excessive water/coolant temperatures; so there were several suggestions including 'in hose' temp measurement. This is what I posted:-
"Now that I've spent another few minutes thinking about it; a water PRESSURE warning light/alarm is the way to go and not water temperature.
 Coolant temperature is NOT engine temperature!
Whilst measuring temperature of water seemed to make sense at the outset.
 What temperature do you set it at as a warning?
The system is designed to operate at or above 100 deg C.
However:
For any given system, temperature of coolant is limited by its maximum pressure which is determined by the coolant filler cap.
 For every individual car the mixture of coolant :: water; and the coolant boiling characteristics, will be somewhat unique and will even vary from time to time within the same car.
 The only constant will be what pressure will crack open the filler cap. (Caps do vary in themselves too); including leakages due to crud build-up [eliminated by annual inspection ].
An alarm/ flashing LED on the instrument panel linked to a preset pressure will inform the driver of imminent coolant loss be it from impending over heating or the start of a gasket leak.
 :lol: Miser's Must-Have Monitors Ltd" :lol:
Mark-The-Miser-UK
Reply #1September 02, 2006, 09:35:45 pm
LeeG
  • 401
« Reply #1 on: September 02, 2006, 09:35:45 pm »
^ place I worked many years ago did that to all the forklifts and lumber carriers.  They also had a sensor for low oil pressure wired in, and the whole works wired up to various ignition systems or fuel shutoffs.  No buzzer, just a sudden stopage!
'97 Passat TDI
Reply #2September 03, 2006, 02:24:48 am
Mark(The Miser)UK
  • 1557
« Reply #2 on: September 03, 2006, 02:24:48 am »
Quote from: libbybapa
Kinda okay for forklifts, but not good in the car when crossing the railroad tracks.
Andrew
Yes I nearly fell into that auto cut off bear pit; but thought of fast lane on interstate situ. Mindyou  overloading forklift with a giant hunk of something eg supporting corner of some structure only to have it cut out.... :shock:
So what we need is a duel pod with EGT and Water pressure...
Mark-The-Miser-UK
