Author Topic: Idler Pulley  (Read 3398 times)
August 01, 2010, 08:36:22 pm
Big Daddy Roth
  • 298
Idler Pulley
« on: August 01, 2010, 08:36:22 pm »
1.9TD
The serp belt idler pulley located on the P/S bracket. It guides the belt to the A/C compressor.
Anyone know the P/N? I'm having trouble sourcing one.
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1August 01, 2010, 08:38:46 pm
Re: Idler Pulley
« Reply #1 on: August 01, 2010, 08:38:46 pm »
Yup, as far as anyone's been able to determine the pulley is NLA as a separate part, if it ever was.
Reply #2August 01, 2010, 08:45:34 pm
Big Daddy Roth
  • 298
Re: Idler Pulley
« Reply #2 on: August 01, 2010, 08:45:34 pm »
Awesome.
So now what do I do? Just remove it? Can the belt pass between the water pump and P/S pump with out it?
1993 TD B3 Sedan
Reply #3August 01, 2010, 08:52:21 pm
Re: Idler Pulley
« Reply #3 on: August 01, 2010, 08:52:21 pm »
Just to be clear... I'm thinking you're talking about the spring-loaded tensioner pulley.
If so... the solution is to buy a new tensioner assembly... or find one at a junk yard.
If you're talking about the relay roller, the part number is 028 145 278E.... probably a dealer-only part at this point.
« Last Edit: August 01, 2010, 09:01:08 pm by Vincent Waldon »
Reply #4August 01, 2010, 09:15:00 pm
Big Daddy Roth
  • 298
Re: Idler Pulley
« Reply #4 on: August 01, 2010, 09:15:00 pm »
Not the pulley on the spring loaded arm. I'm looking for the little one that bolts to the steel bracket that the P/S pump adjusts on.
1993 TD B3 Sedan
Reply #5August 01, 2010, 09:25:44 pm
Re: Idler Pulley
« Reply #5 on: August 01, 2010, 09:25:44 pm »
K, if we're now on the same page that's the relay roller.. the part number shows in stock at Bestpriceautoparts.ca, for one:
http://www.importcarpartscanada.ca/item.wws?sku=W0133-1628203&itempk=70030&mfr=INA&weight=0.45
Reply #6August 01, 2010, 09:37:41 pm
Big Daddy Roth
  • 298
Re: Idler Pulley
« Reply #6 on: August 01, 2010, 09:37:41 pm »
That looks like it. Got a VAG P/N for it?
1993 TD B3 Sedan
Reply #7August 01, 2010, 09:48:04 pm
Re: Idler Pulley
« Reply #7 on: August 01, 2010, 09:48:04 pm »
Ummmm.... look 4 posts up??!!   ;)
Reply #8August 01, 2010, 10:03:32 pm
Big Daddy Roth
  • 298
Re: Idler Pulley
« Reply #8 on: August 01, 2010, 10:03:32 pm »
werd
thxs dude
1993 TD B3 Sedan
Reply #9August 01, 2010, 10:06:22 pm
Big Daddy Roth
  • 298
Re: Idler Pulley
« Reply #9 on: August 01, 2010, 10:06:22 pm »
No, that P/N is for the spring loaded tensioner wheel.
1993 TD B3 Sedan
Reply #10August 01, 2010, 10:09:39 pm
Re: Idler Pulley
« Reply #10 on: August 01, 2010, 10:09:39 pm »
That's the P/N ETKA gives me for the relay roller, also the part number I searched for at Bestpriceauto.
"tis all I know on this one... over and out.
« Last Edit: August 01, 2010, 10:12:33 pm by Vincent Waldon »
Reply #11August 01, 2010, 10:19:55 pm
Big Daddy Roth
  • 298
Re: Idler Pulley
« Reply #11 on: August 01, 2010, 10:19:55 pm »
Yeah, you're not easily gonna find this one in ETKA. I can't find it.
1993 TD B3 Sedan
Reply #12August 01, 2010, 10:48:41 pm
Re: Idler Pulley
« Reply #12 on: August 01, 2010, 10:48:41 pm »
Dealer sometimes knows where to look for stuff in ETKA in corners I'd never dream of...
Reply #13August 02, 2010, 08:41:19 am
macka
  • 957
Re: Idler Pulley
« Reply #13 on: August 02, 2010, 08:41:19 am »
I'd say call Nicole in Thunder Bay ON at the dub dealership. She is a parts guru. There is also a store in Calgary that does dub only sourcing, can't recall the name off hand.
Quote from: Vincent Walden
Reply #14August 02, 2010, 10:56:35 am
Big Daddy Roth
  • 298
Re: Idler Pulley
« Reply #14 on: August 02, 2010, 10:56:35 am »
Don't need it. I deleted it.
1993 TD B3 Sedan
