A/C pump in MK1 Rabbit - AAZ convertion
Topic: A/C pump in MK1 Rabbit - AAZ convertion (Read 3424 times)
July 25, 2010, 12:21:21 pm
1.9TD Caddy
July 25, 2010, 12:21:21 pm »
Helllo all,
I finally installed my rebuilt AAZ in my 81 caddy. The problem I am facing now is that the A/C pump will not fit. The space between the bracket and front frame is too small. I used the braket from the original AAZ engine. Do have to cut out the front fame? Does any one have any ideas? Thanks!
http://i580.photobucket.com/albums/ss245/AYANKAH/1981%20Rabbit%20PickUp%20Build/ACPump001.jpg
July 25, 2010, 04:34:24 pm
dieselherb1
Re: A/C pump in MK1 Rabbit - AAZ convertion
July 25, 2010, 04:34:24 pm »
You have to cut the frame on a TDI engine w/AC. I thought I read online about using the older AC brackets.
July 25, 2010, 08:56:26 pm
GEE-BEE
July 25, 2010, 08:56:26 pm »
ASK Jeff
AT OLDFOLKSHOME.COM, IT WONT FIT...
Wont work, been there done that
1.6 TD yes, AAZ & TDI no
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
July 29, 2010, 01:43:40 pm
dieselherb1
July 29, 2010, 01:43:40 pm »
There is fella on Fred's TDI page who is doing a TDI w/ac into a caddy. He has knotched the frame, but I don't know what hoses he is using. Said he was going to install a Corrado dash witha Passat heater/ac box. I want A/C in my Caddy and a MTDI engine. Wonder if you can swap A/C pulleys v belt-serp.?
July 29, 2010, 06:09:56 pm
1.9TD Caddy
July 29, 2010, 06:09:56 pm »
My set up has the serp pulley with the I.9 TD bracket. I dont think the v belt set up will make a difference. I wonder if your Buddy has a pic of the notch to share.
August 02, 2010, 08:16:39 am
1.9TD Caddy
August 02, 2010, 08:16:39 am »
Thanks to Dieselherb1 I tracked down a post on TDICLUB.com. It looks like to install your A/C pump on an AAZ set up in a Mark1 rabbit you will have to notch out the forward frame so the pump can fit. Here is a link to a tread where it has been done.
http://forums.tdiclub.com/showthread.php?t=281944
