Author Topic: Meth injection  (Read 3721 times)
July 15, 2010, 11:30:11 pm
myvolkswagen
  • 96
Meth injection
« on: July 15, 2010, 11:30:11 pm »
Does anyone on here do it? I'm thinking of running it on my car. Any reviews?
Reply #1July 16, 2010, 12:17:23 am
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
Re: Meth injection
« Reply #1 on: July 16, 2010, 12:17:23 am »
Check this thread out. http://www.vwdiesel.net/forum/index.php?topic=10150.0
Sorry for the pic links not working in my posts.
« Last Edit: July 16, 2010, 12:20:17 am by Sierra94 »
<-- My M-tdi Mazda B-1800 and my other cars
Reply #2July 16, 2010, 09:58:05 am
Re: Meth injection
« Reply #2 on: July 16, 2010, 09:58:05 am »
can you not run an intercooler? thats all meth injection is, a chemical intercooler.
Reply #3July 17, 2010, 05:44:32 pm
Henchman
  • 183
Re: Meth injection
« Reply #3 on: July 17, 2010, 05:44:32 pm »
Meth meth/water would also increase compression ratio and cool exhaust temps.
Ian
Reply #4July 17, 2010, 09:36:31 pm
myvolkswagen
  • 96
Re: Meth injection
« Reply #4 on: July 17, 2010, 09:36:31 pm »
All the local guys run intercoolers and meth/water on their ALH tdi's thats why i was wondering if anyone on here does it. seems well worth it to me
Reply #5July 18, 2010, 08:30:52 am
dts67
  • 68
Re: Meth injection
« Reply #5 on: July 18, 2010, 08:30:52 am »
It'll give you a little bit of power from the meth(dont expect much) and on a poor or no ic setup will lower charge temps, I have tmic and it reduces charge temp from 70 to 40deg iirc(celsius). The water reduces egt a small amount and lets you run a little more fuel.
Reply #6July 18, 2010, 09:51:46 am
OM617
Re: Meth injection
« Reply #6 on: July 18, 2010, 09:51:46 am »
The primary benefit is to keep the engine carbon-free for maximum lifespan and efficiency. Cooler intake air and additional fuel are just a bonus.
Reply #7July 19, 2010, 02:47:48 am
dts67
  • 68
Re: Meth injection
« Reply #7 on: July 19, 2010, 02:47:48 am »
forgot that bit and having had the manifolds off after near 20k of w/m can confirm insides are spotless.
Reply #8July 24, 2010, 02:42:11 pm
OM617
Re: Meth injection
« Reply #8 on: July 24, 2010, 02:42:11 pm »
The other side of that is its far more important than ever that the oil be frequently brought up to operating temperature to boil off the increased moisture contamination. Coolant temperature does not correlate to oil temp.
