Author Topic: Foamy Diesel  (Read 3524 times)
November 20, 2007, 07:44:52 am
Op-Ivy
  • 513
Foamy Diesel
« on: November 20, 2007, 07:44:52 am »
When filling up I only get 40ish litres in. If I wait another minute for the foam to go down I get another 10 in. When pumping some into a jerry can I notice that before it is even half full it has foamed up to the top. It started doing this back early October...
Has anyone else noticed that the diesel at gas stations lately has been extra foamy? Maybe this has to do with the winter diesel?
Matt
Reply #1November 20, 2007, 08:56:45 am
Foamy Diesel
« Reply #1 on: November 20, 2007, 08:56:45 am »
I've found that it's always been really foamy. If I take my time I can usually add another 3-5L to my tank
Reply #2November 20, 2007, 09:31:38 am
andybnwc
Foamy Diesel
« Reply #2 on: November 20, 2007, 09:31:38 am »
I know in the uk some fuel companys put detergents in the fuel so this maybe why
Reply #3November 20, 2007, 10:27:04 am
Jetta Fan
  • 286
Foamy Diesel
« Reply #3 on: November 20, 2007, 10:27:04 am »
Furnace oil is the same way...mind you, it's just #2 diesel with dye and a lot less tax.  :lol:
But I have noticed the diesel is a bit more foamy lately. At some stations with a slower pump, I can get more in before it kicks out and then can't squeeze in as much after waiting as I can at a station with a faster pump. I wonder if it has anything to do with the ULSD garbage they are selling us?
1997 Jetta 1.9TD AAZ
Reply #4November 20, 2007, 11:01:26 am
Vanagoner
  • 219
Foamy Diesel
« Reply #4 on: November 20, 2007, 11:01:26 am »
100% biodiesel= 0% foam
even a blend knocks the foam down considerably.
maybe the oil companies have struck a deal with procter & gamble javascript:emoticon(':)')
Sage
Reply #5November 20, 2007, 04:05:54 pm
Foamy Diesel
« Reply #5 on: November 20, 2007, 04:05:54 pm »
yeah, I can slowly fit in two more gallons after the pump shuts off, a real pain when it's -20F out. I've noticed some fuel is worse than others.
Reply #6November 20, 2007, 05:11:05 pm
Op-Ivy
  • 513
Foamy Diesel
« Reply #6 on: November 20, 2007, 05:11:05 pm »
Quote from: "libbybapa"
That's interesting.  That would mean that the rate of flow at the pump and the foaming action of the fuel has a significant impact on the point the pump shuts off.  I've always filled up until the first automatic click-off assuming the amount in the tank was consistent in order to gauge fuel economy.  Foam has been screwing with my calculations?  Dang...
Andrew
Yea... I thought about that a while ago too. Disappointing to not have an accurate way to calculate "smilage". If someone has a good way, then I'm all ears.
Matt
Reply #7November 20, 2007, 07:18:56 pm
bigblockchev
  • 271
foam
« Reply #7 on: November 20, 2007, 07:18:56 pm »
There is a little button nub inside the filler neck which allows the tank vent open and vent off trapped air in the tank. This allows you to fill the tank completely up and get more accurate levels when calculating fuel mileage. You have to push it down with your finger or the fuel nozzle and listen for the air whooshing out as well as watch the fuel drop down the filler neck. I fill up in my sloped driveway all the time so I have to do this or get inaccurate results. It is on MK2 & MK3 at the least that I know of. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #8November 20, 2007, 07:41:50 pm
Turbinepowered
  • 1206
Foamy Diesel
« Reply #8 on: November 20, 2007, 07:41:50 pm »
Quote from: "Op-Ivy"
Whenever I fill up the bus, I always fill it to the same mark on the filler neck. Of course, the filler necks on those are also nearly two and a half inches in diameter, so it's pretty easy to see inside them.
Reply #9November 21, 2007, 12:40:01 pm
Foamy Diesel
« Reply #9 on: November 21, 2007, 12:40:01 pm »
I've heard rabbits don't have the button inside the neck so there's nothing you can do to speed it up. I always fill mine right to the top of the neck and it seems consistent enough.
Reply #10November 22, 2007, 05:00:56 am
Jetta Fan
  • 286
Foamy Diesel
« Reply #10 on: November 22, 2007, 05:00:56 am »
For a more accurate mileage calculation, do it over sevral tanks of fuel (say 10). This way, the little fluctuation caused by the foaming fuel will not be such an impact.
