Author Topic: first time with timing tools  (Read 9251 times)
October 23, 2007, 05:37:49 am
carrizog60
  • 978
« on: October 23, 2007, 05:37:49 am »
hello
i just bought a timing tools kit and i would appreciate a little help on working with this...
the kit is this:
can someone explain what need to be put together and how does the gauge adjusters work?
sorry for the newbieness :oops:
Portugal
Reply #1October 23, 2007, 07:10:33 am
« Reply #1 on: October 23, 2007, 07:10:33 am »
ok basically there is a 12mm bolt on the end of the pump. Remove that and then thread in one of the shafts. Then slide in one of those smaller rods then screw the dial gauge onto the shaft and preload it to 1.00mm
Reply #2October 23, 2007, 07:15:11 am
subsonic
  • 1836
« Reply #2 on: October 23, 2007, 07:15:11 am »
I am going to be doing the same thing shortly, and asking the same questions.  How about doing a how to pictoral and putting it in the FAQ?  I kind of need to see things along with reading the directions to get a better understaning of the process.
Reply #3October 23, 2007, 07:59:00 am
« Reply #3 on: October 23, 2007, 07:59:00 am »
Here is a bit of a FAQ Benjamin and I made, feel free to contribute but I will delete questions from the thread (the FAQ, not this one)
http://vwdiesel.net/phpBB/viewtopic.php?t=10569
Reply #4October 23, 2007, 12:53:29 pm
carrizog60
  • 978
« Reply #4 on: October 23, 2007, 12:53:29 pm »
how can i reset to zero?
and to preload?
the only way of the needle to move is pressing forward...or not?
the smaller adjuster on the "side" of the gauge doesn't move...and has a plastic piece between gauge and adjuster...should be removed to work?whats is function?
what for is the parts shown in the 3 picture?
one is solid and the other (U shaped) is for?lock the camshaft?how?
sorry for all the questions but a "timing tools introduction /presentation and diy timing for dumb ass newbies" is required...
something like " insert this into this, this way.." :lol:  :oops:  :oops:
Portugal
Reply #5October 23, 2007, 02:53:29 pm
« Reply #5 on: October 23, 2007, 02:53:29 pm »
Quote from: "burn_your_money"
I'm working on a pictoral HOW-TO as well, since it's a bit tricky and comes up all the time... but it's about a month away...
You "zero" the gauge by rotating the dial until the needle points to 0.
"Pre-load" means making sure the dial gauge has some room to travel ie isn't at the end of its range.
The long bar locks the camshaft at exactly TDC... best bet is to look up the proceedure in the Bentley.. there are pictures of both the cam lock in action and how the dial indicator fits into the pump.
Reply #6October 23, 2007, 03:31:53 pm
slorimer
  • 52
« Reply #6 on: October 23, 2007, 03:31:53 pm »
Hey carrizog60
Where did you get that timing tool kit?  How much?
94 1.9TD
Reply #7October 23, 2007, 05:22:24 pm
rabfan
  • 28
« Reply #7 on: October 23, 2007, 05:22:24 pm »
Yeah, that's a nice one for sure. It blows the kit I just bought away......
Reply #8October 23, 2007, 09:45:49 pm
jolotter
  • 67
« Reply #8 on: October 23, 2007, 09:45:49 pm »
That is a nice kit.  My gauge, as well as reading in inches (I measure lumber in inches, cars in mm,) has some significant side to side play at the end of the extention.  I think it drags up the cam lobe and gives me a lower reading than actual.  That translates to more advance, not so bad, so long as you account for it.  I think I'll make a guide bushing to put in the end of the adapter.
I also ground some flats on the adapter so I could get my 17mm wrench on to snug it up.
Johann
83.5 Vanagon soon to be equipped with
1990 1.6 TD engine
93 Golf 1.9TD and spare engine/tranny
Reply #9October 24, 2007, 10:10:05 am
carrizog60
  • 978
« Reply #9 on: October 24, 2007, 10:10:05 am »
the kit came from ebay,62€ with dispache to portugal from germany.
as soon as i get home i will provide the link :wink:
edit:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330179976466&ssPageName=MERC_VIC_RCRX_Pr4_PcY_BIN_IT&refitem=330173847643&itemcount=4&refwidgetloc=closed_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget
 :wink:
can anyone scan the bentley on this procedure?
Portugal
Reply #10October 28, 2007, 11:54:23 am
carrizog60
  • 978
« Reply #10 on: October 28, 2007, 11:54:23 am »
hope its not forgotten...
Portugal
Reply #11October 28, 2007, 03:45:07 pm
numbnuts
  • 99
« Reply #11 on: October 28, 2007, 03:45:07 pm »
so do i need a kit like this to change the timing belt? I am gonna do it at xmas, but was planning on marking up the pulley positions, and just sliding off the belt and replacing as with every other petrol golf cambelt i have done. Is this not the way to do it then? :oops:
Reply #12October 28, 2007, 09:54:56 pm
tylernt
  • 344
« Reply #12 on: October 28, 2007, 09:54:56 pm »
Quote from: "numbnuts"
It's recommended that you adjust the timing with a new belt. If you don't mess with the pump mounting bolts, the timing will theoretically not change much. In practice, I have no idea. What we need to do is have someone check the timing with an old belt, replace the belt, and check the timing again to see if it moved and if it's still within spec.
Part of the reason they want you to adjust the pump timing is because you are supposed to reset the cam timing (no keyway on the cam sprocket) too.
Reply #13October 29, 2007, 05:35:40 am
Ziptar
  • 565
« Reply #13 on: October 29, 2007, 05:35:40 am »
Not to thread jack but, I just bought a set of VW Specialty tools on ebay.
Looks like almost every thing I need to change a timing belt is there except the locking pin. I can get the Pin fro $9.50 from
 zdmak.com, they are actually based in Sarasota only a half hour from me.
is this the correct tool for measuring belt tension?
http://www.zdmak.com/wbstore/main.asp?action=PROD&PROD=MK-142BG&CTMP=1
Is it worth having for $50?
Reply #14October 29, 2007, 07:24:58 am
tylernt
  • 344
« Reply #14 on: October 29, 2007, 07:24:58 am »
Nice kit. Is the socket-on-a-handle for the struts?
You can use a deep socket in place of the pump locking tool.
The tensioning tool would be nice to have... I can twist my belt 45* but I still worry about the correct tension. I guess for Mk3 and later Bentleys, the book requires the tool instead of offering the alternate twist method. But $50? Yikes.
