Author Topic: Cold start choke  (Read 2232 times)
November 26, 2007, 08:37:21 am
doc_oc
  • 49
Cold start choke
« on: November 26, 2007, 08:37:21 am »
I am not sure how to use it and what does it do? Can anyone educate me please?
And if, I drive the car for about 40 minutes till I realize I forgot to push it back in, is there a problem?
Thanks.
1995 Passat GLS
99.5 Golf TDI RIP
Reply #1November 26, 2007, 10:58:13 am
Cold start choke
« Reply #1 on: November 26, 2007, 10:58:13 am »
It advances the timing and raises the RPM. I always just leave mine out. The timing advance is overriden at 2200 RPM IIRC
Reply #2November 26, 2007, 11:13:08 am
doc_oc
  • 49
Cold start choke
« Reply #2 on: November 26, 2007, 11:13:08 am »
Mine seems to be starting better with it in the cold but the RPM is not moddified at all. Cold or warm.
1995 Passat GLS
99.5 Golf TDI RIP
Reply #3November 26, 2007, 11:46:05 am
lyeinyoureye
  • 96
Cold start choke
« Reply #3 on: November 26, 2007, 11:46:05 am »
Quote from: "burn_your_money"
Ya know, I just figured something out. In all their charts, Bosch never uses exact figures because the high idle/etc can all be set to different things. For instance, on a stock pump designed to rev to 5k rpm, it looks like the advance of ~2.5 degrees would start increasing again w/ the CS out after 2200rpm like ya said, but if the pump only revs to 4k rpm, or up to 6k rpm, because of the lower or higher high idle, then the KSB timing cuts out at a proportionally lower or higher engine speed.
