Author Topic: what are the best injectors?  (Read 8898 times)
March 21, 2008, 06:36:33 pm
oldskool rich
  • 446
« on: March 21, 2008, 06:36:33 pm »
i hav an AAZ with 11mm pump piston ect, ive spoke to alot of people and no one can giv me a straight answer
ive established that merc nozzles are best however some of the big power AAZs that ive seen are running 1.6 injectors
so i thort id coppy this trend, however im not conviced that they produce any more power :?
the 1.6 injectors are (if im not mistaken) designed to open at a lower pressure
the 1.9s have two springs, im not quite sure what for?
there must be a reason
i just wana know once and for all which one is better?
and if anyone knows why two springs?
also are there any other injectors available that will do an even better job?
f6squared I.D.S.T
Reply #1March 21, 2008, 07:10:40 pm
BleachedBora
  • Administrator
  • 104
    • Cascade German Parts
« Reply #1 on: March 21, 2008, 07:10:40 pm »
'81 CBEA Caddy, '81 DeLorean, '98 Defender TDI, Too many VAG to list
www.cascadegerman.com
Sales and support: [email protected]
Reply #2March 21, 2008, 08:08:19 pm
diesel smoke
  • 209
« Reply #2 on: March 21, 2008, 08:08:19 pm »
Soon I will be putting Mercedes 300D nozzles in my Jetta...
As for the 2 springs in the injector, it is designed to give the engine a smoother run; in that the weaker spring will open the nozzle early, allowing a little fuel to spray; then as the pressure rises even more the stiffer spring allows the injector to spray alot, then as the pressure drops off the stiffer spring closes and the weaker spring allows the injector to spray a little bit more. the result is a quieter engine.
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #3March 21, 2008, 08:40:26 pm
subsonic
  • 1836
« Reply #3 on: March 21, 2008, 08:40:26 pm »
Some where in here there is a discussion about the 1.6 vs the 1.9 injectors and all the differences.  I just looked for a bit but could not find it.  Just saw it yesterday to damn it!  Or if you REALLY want to go big, do a search for 8S2.
Reply #4March 22, 2008, 05:31:56 am
oldskool rich
  • 446
« Reply #4 on: March 22, 2008, 05:31:56 am »
Quote from: "subsonic"
had a look, seems like 8S2 nozzles realy arnt ment for these engines as they deliver 3 times more fuel, maybe a good upgrade for a tractor though
sum people say they lost 10 bhp by using gtd injectors, i feel the same and so im going back to standard but keeping the merc nozzles :roll:
f6squared I.D.S.T
Reply #5March 22, 2008, 03:13:16 pm
snakemaster
  • 405
« Reply #5 on: March 22, 2008, 03:13:16 pm »
Hey bro stick a set of bosch pug 1.9 td injectors  in your wild wagon, made a difrance to my 1.6 td golf would pull 125 mph , on a dirt track road, but my wheels did not stick out past the arches ,  :lol: probly cut 15mph of for that , get some 145 80 13 on some 4j rims  :lol:
Reply #6March 23, 2008, 02:24:18 am
Benjamin
  • 485
« Reply #6 on: March 23, 2008, 02:24:18 am »
Quote from: "snakemaster"
do you mean the 175bar injectors?
there are 2 difrent injectors, the one are 155 and the other something like 175bar.
i think you will need stronger anti-return springs as well if you raise the pressure.
Greetz, Benjamin
Must make +250hp
Reply #7March 23, 2008, 10:30:21 am
« Reply #7 on: March 23, 2008, 10:30:21 am »
the butt dyno seems to tell me that i've lost about 10 hp going from GTD's back to regular TD's.
Reply #8March 23, 2008, 10:40:56 am
« Reply #8 on: March 23, 2008, 10:40:56 am »
Quote from: "Benjamin"
Greetz, Benjamin
I didn't put stronger anti-return springs on when I changed to TDI injectors at 220 bar. Is that something that has to be done?
Reply #9March 23, 2008, 06:23:34 pm
oldskool rich
  • 446
« Reply #9 on: March 23, 2008, 06:23:34 pm »
Quote from: "jtanguay"
hang on a sec, i thort that GTDs wer the same as 1.6s
im using injectors off an old solid lifter n/a 1.6
i saw audi80 running them in that 225hp rocco, i assumed that there was a reason behind it.
sounds like i maybe loosing upto 20hp by using these :oops:
or am i understanding whats been said properly?
f6squared I.D.S.T
Reply #10March 23, 2008, 06:34:36 pm
Rvo
  • 8
« Reply #10 on: March 23, 2008, 06:34:36 pm »
GTD nozzles are from the 1.6td with a standard intercooler (engine code SB and i think RA), the 80hp ones. Built from 90-92... The ones you have are from an older model 1.6 :)
 grts Ronald
Reply #11March 24, 2008, 07:27:31 am
MJF
  • 581
« Reply #11 on: March 24, 2008, 07:27:31 am »
Quote from: "oldskool rich"
No reason for these, just stock ones. I still donīt believe there is much differences in power, I donīt believe in butt dynos :)
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #12March 24, 2008, 10:54:02 am
mdonau
  • 53
« Reply #12 on: March 24, 2008, 10:54:02 am »
Pug 1,9TD Nozzles are DN0SD299(C) type,
they are a little bigger than the most common 1,9TD VW-type DN0SD297
i would only take the 299-Type for racing or extreme performance due to hard combustion-sound.
the original 297's give good cold-start (SVO/WVO-Drivers 1. choice) and
a smoother (and better) combustion, caused by the way the needle is
grinded to make a pre-injection. The *308, *294, *273 types will also do fine.
bigger Nozzles are not really needed, because they flow much more than DI-Types.
i am running 297's adjusted to pop at 175 Bar in my Audi..runs great :)
so why go for Mercedes-Nozzles?
EDIT: the most common type for the 1,6 (N/A) or turbo was *293.. GTD or whatever (JR, RA, SB, JX etc.) they work, but not as good as the more modern types listed above.
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
Reply #13March 24, 2008, 03:41:54 pm
carrizog60
  • 978
« Reply #13 on: March 24, 2008, 03:41:54 pm »
what do you say about dn0sd 261?
Portugal
Reply #14March 24, 2008, 03:49:55 pm
rallydiesel
  • 1880
« Reply #14 on: March 24, 2008, 03:49:55 pm »
It seems to me that getting your pump tuned is a better upgrade than changing injectors/nozzles.  :?:
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
