Author Topic: what are the best injectors?  (Read 8889 times)
Reply #15March 24, 2008, 04:33:04 pm
mdonau
  • 53
« Reply #15 on: March 24, 2008, 04:33:04 pm »
Quote from: "rallydiesel"
It seems to me that getting your pump tuned is a better upgrade than changing injectors/nozzles.  :?:
thats the point! took me more than 5 hours to get a usable adjustment..
Quote from: "carrizog60"
what do you say about dn0sd 261?
261 and 265 are equal to the 297 and similar but for mercedes..
The question is:
are nozzles for prechamber-engines with row-pumps good for
whirl-chamber-engines with distributor-pumps?
if you mount stock merc. injectors (pops at 115Bar) and do no adjustment
 on the pump, the injected volume will increase, because the nozzles opens earlier.
->looking at it this way, the engine will perform better, but atomisation will be worse.
Thats no problem in an mercedes, the precamber is built to compensate.
The VW-turbo-nozzles pop at 155 Bar.. good atomisation is required for fast combustion.
The Injection-time is shorter, burning is finished earlier:
results in better performance, thats also what a bigger plunger makes, but without
the disadvantages of poorer atomisation by lowering pop-pressure.
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
Reply #16March 24, 2008, 06:01:27 pm
oldskool rich
  • 446
« Reply #16 on: March 24, 2008, 06:01:27 pm »
Quote from: "MJF"
Quote from: "oldskool rich"
im using injectors off an old solid lifter n/a 1.6
i saw audi80 running them in that 225hp rocco, i assumed that there was a reason behind it.
No reason for these, just stock ones. I still donīt believe there is much differences in power, I donīt believe in butt dynos :)
first of all, much respect to you, i love your work, its what got me into diesels.
if different injectors arent a big deal, what is? where do you get all your power? is it just the VNT? my pump is tuned quite a lot and it hasnt made as much different as i thort it would, any suggestions? :roll:
if i cant crack it im gona get a supercharger too, it just takes so long to build boost with a T3
f6squared I.D.S.T
Reply #17March 24, 2008, 06:05:02 pm
« Reply #17 on: March 24, 2008, 06:05:02 pm »
i think his intake, big turbo, big boost, intercooler, big exhaust, and injection pump pump are where the power comes from.
Reply #18March 24, 2008, 10:02:59 pm
« Reply #18 on: March 24, 2008, 10:02:59 pm »
1000X... imho the nozzles, assuming they are fresh and well-calibrated, are virtually insignificant in terms of performance upgrade potential for us daily drivers.
There's tons you can do with a stock VW in terms of better fueling, breathing, and charge cooling.... huge payback compared to fooling around with nozzle differences only visible under a scanning electron microscope !!  ;-)
Reply #19March 25, 2008, 01:12:14 am
MJF
  • 581
« Reply #19 on: March 25, 2008, 01:12:14 am »
Quote from: "Trev0rbr"
i think his intake, big turbo, big boost, intercooler, big exhaust, and injection pump are where the power comes from.
Fuel pump is most important. Itīs the pump that delivers fuel, not injectors :) With those mods above, you can get easily up to 180hp from otherwise stock 1,6 engine.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #20March 25, 2008, 07:04:10 pm
oldskool rich
  • 446
« Reply #20 on: March 25, 2008, 07:04:10 pm »
Quote from: "MJF"
my pump has 11mm pump piston, gov mod, gtd boost pin, i hav a short stainless 2.5" straight through exhaust, t3 with closed waste gate, landrover intercooler, maybe im just being fussy, i just expected a little more
f6squared I.D.S.T
Reply #21March 26, 2008, 12:41:36 am
MJF
  • 581
« Reply #21 on: March 26, 2008, 12:41:36 am »
How much hpīs do you have now? Stock 1,6 T3 is small, have you measured your exhasut manifold pressures?
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #22March 26, 2008, 06:01:41 pm
oldskool rich
  • 446
« Reply #22 on: March 26, 2008, 06:01:41 pm »
tbh im having clutch trouble so its hard to say, i recon 150 at the moment
exhaust manifold pressure? what will that tell me?
f6squared I.D.S.T
Reply #23March 26, 2008, 06:53:27 pm
hillfolk'r
  • 1532
« Reply #23 on: March 26, 2008, 06:53:27 pm »
Quote from: "MJF"
yea i sorta gotta call that out 180hp 1.6??
hmm when my gtech is telling my 140 hp on my tdi-m,and im knocking on the door of 13 second 1/4's
12mm pump,and race 520 nozzles,mucho boost too(30+psi)
Throttle cables ftw
Reply #24March 26, 2008, 08:18:33 pm
hillfolk'r
  • 1532
« Reply #24 on: March 26, 2008, 08:18:33 pm »
my old1.6td made a centerforce dualfriction clutch slip...........
Throttle cables ftw
Reply #25March 27, 2008, 02:27:40 pm
MJF
  • 581
« Reply #25 on: March 27, 2008, 02:27:40 pm »
EMP shouldnīt be much higher than boost, otherwise your turbo is choking the engine. And before anyone says, yes it is possible. 150hp from stock t3 is already a lot IMO.
Hillfolkīr: I always speak crank hpīs, becouse thatīs what we measure in dynoīs here. Iīve once used gtech for my Audi. It showed 143hp, when dyno told 151whp and 173 crank hp. Low 14īs is no problem with 150whp in light car like yours.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #26March 28, 2008, 09:07:13 am
oldskool rich
  • 446
« Reply #26 on: March 28, 2008, 09:07:13 am »
wow i didnt think it was that fast.
will be trying it down the strip soon, the main thing holding me back is my top end. the tdi gear box with 13" wheels wont let me do over a hundred :cry:
f6squared I.D.S.T
