Author Topic: Anyone have a mk2 NA with a AWY tranny?  (Read 6149 times)
March 02, 2008, 05:27:20 am
« on: March 02, 2008, 05:27:20 am »
I see that my highway speeds will be around 4000 RPM. What kind of mileage do you get at these speeds?
Reply #1March 02, 2008, 07:04:43 am
Patrick
  • 1034
« Reply #1 on: March 02, 2008, 07:04:43 am »
My wife is driving a mk2 golf with that tranny. Running close to 50 mpg (as much as 950km on a tank) Not a lot of 4 lane running, mostly 2 lane back and forth to work.  Wouldn't want gearing any higher with the stock 1.6na engine, not enough grunt to handle any more gear.
Reply #2March 02, 2008, 02:17:15 pm
Quantum TD
  • 1195
Re: Anyone have a mk2 NA with a AWY tranny?
« Reply #2 on: March 02, 2008, 02:17:15 pm »
Quote from: "burn_your_money"
That's about the worst tranny-engine match VW ever imagined. I think they were trying to make the 1.6NA in those years feel "sporty". It's great to accelerate up to 50 MPH, but after that, you're winding out the motor and putting excessive wear on it. I had one on my 1991 Jetta Coupe, I couldnt' get rid of it soon enough.
With that trans in there, I was lucky to get 37-41 MPG on the highway at 65-75 MPH and 4000-4300 RPMs. With a lower 5th geared trans, I was able to drop the RPMs down to about 3300-3600, and improved the fuel economy up to 45-48 on the highway.
Do yourself a favor and start looking for a MK II trans with a 3.94 or 3.89 final drive, and a .75 5th gear. I think that the AOP, ACH, or AGS are the only direct fit trans codes. You may be able to make a MK I trans work. A 4S or a 7A might work,  but you'd have to make sure the final drive housing had the bosses for the MK II mounts.
Good luck.
Reply #3March 02, 2008, 07:48:29 pm
eightyonerabbit
  • 51
« Reply #3 on: March 02, 2008, 07:48:29 pm »
i have an FK tranny (3.89 FD) with a .71 5th gear, and it does awesome on the highway... about 2800 rpm's at 70mph...
Reply #4March 03, 2008, 10:36:09 am
« Reply #4 on: March 03, 2008, 10:36:09 am »
Perfect thanks guys. I'll have to see what I have in stock, I know I have a 7A
Reply #5March 03, 2008, 06:54:53 pm
Quantum TD
  • 1195
« Reply #5 on: March 03, 2008, 06:54:53 pm »
7A should work according to EKTA, but make sure the bosses are all there for the rear trans mount.
Reply #6March 03, 2008, 08:05:46 pm
VelocityConservation
  • 92
AWY Tranny
« Reply #6 on: March 03, 2008, 08:05:46 pm »
I used to have an AWY in my 90 Jetta (when it was NA).  I was getting 44mpg no matter what type of driving or speeds.
GO TALLER young man.
That 3.94 rp with the .89 5th is brutal for anything over 55mph.  The motor finally let loose like a grenade while on an interstate doing 67mph (3472 rpm (calculated), right on the governor).
http://i96.photobucket.com/albums/l193/PhlatOut_2006/Diesel-brokenrod-01.jpg
I had a FF put in the mk2 case with a .76 5th and I still wish I had gotten bold and put a 3.67rp and .71 5th in it.  I put a TD in at the same time so mpg results don't compare.
Fortunately my commute is mostly surface streets and 55 is the top speed I see on regular occasion.  It is still short enough that I take my gasser if I am going to be on an interstate for more than 30 min.
90 TD Jetta, NA to TD swap completed '07
Reply #7March 03, 2008, 08:20:38 pm
Quantum TD
  • 1195
« Reply #7 on: March 03, 2008, 08:20:38 pm »
Ooooh. 3.67 R&P. I'm not so sure about that. With a 1.6, you really need at least 3.89. I put a 3.67 on a 1.6 NA, and I'd roast the clutch trying to reverse, or taking off in first gear. It was great on the highway, I could cruise at 80 MPH all day long, but getting the car up to that speed was a challenge to say the least.
Reply #8March 04, 2008, 03:59:18 am
91MF
« Reply #8 on: March 04, 2008, 03:59:18 am »
this is interesting. im new to diesels and dunno about all these transmissions. is there a list somewheres of these trans codes and their guts. like, is there a magical super tall trans? lolz
Reply #9March 04, 2008, 08:03:46 am
« Reply #9 on: March 04, 2008, 08:03:46 am »
Quote from: "91MF"
http://www.scirocco.org/gears/
Reply #10March 04, 2008, 08:04:56 am
Re: AWY Tranny
« Reply #10 on: March 04, 2008, 08:04:56 am »
Quote from: "VelocityConservation"
I would KILL for a .71 5th.
You want to sell??
Seriously?
Reply #11March 04, 2008, 11:09:32 am
subsonic
  • 1836
« Reply #11 on: March 04, 2008, 11:09:32 am »
Quote from: "Quantum TD"
That setup would be fine you just need more power :D
Reply #12March 04, 2008, 01:11:34 pm
« Reply #12 on: March 04, 2008, 01:11:34 pm »
I found 4 transmissions during lunch with the .75 5th gear.
I think 2 had the 3.67 final and 3 had the 3.94 final.
If anyone is interested in one of these I would be willing to assist.
Drop me a PM so we dont clutter this thread, I'm not really trying to sell transmissions but if anyone needs one like Tyler and I do I'll do what I can to help.
4000 rpm just isn't going to work to well for me either.
I'll be getting me a 3.67 and .75 trans.
These are ACH and ACN coded transmissions.
Reply #13March 04, 2008, 01:15:11 pm
Re: AWY Tranny
« Reply #13 on: March 04, 2008, 01:15:11 pm »
Dude!!!!!!  I have a block that looks JUST like that :)
Bummer huh?
Reply #14March 04, 2008, 01:17:48 pm
« Reply #14 on: March 04, 2008, 01:17:48 pm »
I dont know about that.
I think a 3.67 R&P with a .71 5th would be great. 82 mph @ 3200 rpm.
Sweetness!!
There just inst enough difference in the 3.67 and 3.94 R&P to cause a problem.
