Author Topic: Need help to make my car run low mpg, and another problem  (Read 2865 times)
July 02, 2007, 01:50:36 am
cableroy
  • 19
« on: July 02, 2007, 01:50:36 am »
Hi!
First of i got a 1.6TD engine, witch one i'm not sure, my diesel pumpe does not have this "ufo" at the top, but i got a electric pump between the filter and mechanical pump. Hope this helps?
Well first, my pump is original (not tuned) and my turbo goes 0.65bar to 0.7 depens og witch gear but i'm not happy about my mpg if i calculated correctly witch i'm not 100% sure of, i came to 37,33 mpg(US)or 0.625 per liter pr 10km for mixed driving, people told me i can make it go like 0.4 liter per 10 km so i'm thinking i need to adjust something? Why i think that? Read further down.
This is my first diesel car, but i got experience to petrol cars so modifications might not be a problem for me.
Whats your mpg and with what mods/hp?
There is a problem when i drive on the highway, 5 gear 100+ km/h and coming down a maybe long hill/slope i give less throttle then after a few sec the engine does not go clean and starts to spit out white smoke not constantly but when the engine cough i can see white smoke maybe a little blueish not black, it does not use water so i bet its unburned diesel? What can cause this? I hope my explenation is good enough english is not my native language as you might see.
Reply #1July 02, 2007, 07:39:29 am
« Reply #1 on: July 02, 2007, 07:39:29 am »
I think you should have your timing belt replaced and thent he timing set to about 1.00 and go from there. 0.4/10km is really, really good mileage. 0.5/10km is the upper range of normal
Reply #2July 02, 2007, 08:19:18 am
« Reply #2 on: July 02, 2007, 08:19:18 am »
Yes white smoke with a tinge of blue is usually unburned diesel... first step is definitely to check your timing.
I'm pretty sure a  ECO turbo (sounds like what you have since you don't have the LDA on the pump) would generally get 5.x  - 6.x l / 100 km in mixed driving.   My standard turbo does 5.3l / 100km on the highway if I cruise carefully at 110 km/hm, no wind, no passengers, properly inflated tires, etc... under those conditions I'm running about 3 psi of boost (0.2 bar).
Reply #3July 02, 2007, 08:48:34 am
cableroy
  • 19
« Reply #3 on: July 02, 2007, 08:48:34 am »
Hm is there other place's i can look to verify if its a eco trubo on the engine? The last owner said the engine was changed... so maybe to a eco turbo?
But yes timing it would be the best, since i have had to tie the belt because it was loose, and the belt on the "long" side moved a bit creating annoying sound on the plastic cover. I searched the forum, didn't find a howto just  for the timing only one with advanced mod. Can someone please point me to a good howto with pics just so i'm sure how to do it properly? Thanks
Reply #4July 02, 2007, 09:04:18 am
Re: Need help to make my car run low mpg, and another proble
« Reply #4 on: July 02, 2007, 09:04:18 am »
Quote from: "cableroy"
Hi!
if someone installed an electric lift pump, then that is good, but they probably did it because the pump was sucking in air from a bad seal.  that pump might just be covering up another issue.  if not then be happy as it makes changing filters a breeze!
your pump is definitely eco if there is no spaceship on top... but on the vw buses they had an LDA that was on its side although i doubt you have that.
at this stage, the turbo is merely giving you a more efficient burn at the higher rpm's, and is not really affecting mileage except maybe in town where it takes that little extra pedal or 'lag' to spool up the turbo.
best way to increase mpg is to change all 4 wheel bearings, get new tie rod ends & get a 4 wheel alignment, check tire wear and replace bad tires, balance tires if needed, and i think 40 psi is a general consensus for best mileage, but can increase i think it's called 'cupping'??? (on certain tires)  if your tranny is geared lower (higher rpm's on the highway) that can decrease economy as well.  my setup gives me 100km/h @ 3000 rpm or so, which is convenient because i do not need to shift into 4th going up hills, but for mileage sake i wouldn't mind shifting...
if you do not know the history of this engine, you may want to look into getting the injectors re-built (either new nozzles, or the full rebuild being pressure tested and calibrated) as bad injectors can give smoke as you describe, or even worse, damage your engine.
but for now, the simplest first.  as mentioned above, check your timing.  that is the most likely scenario.
you should also post your location, and what vehicle you drive...  do you use any additives? i notice a power increase when i use power service diesel fuel conditioner.  it boosts the cetane number which helps the diesel burn a little bit better and completely, and also lubricates the pump, and is also an anti-gel.
Reply #5July 02, 2007, 11:03:51 am
« Reply #5 on: July 02, 2007, 11:03:51 am »
Another thing is make sure the electric pump doesn't have a lot of pressure as that will affect your timing as well. Under 10 psi would probably be ok, ith less being better.
Reply #6July 10, 2007, 03:29:46 am
cableroy
  • 19
« Reply #6 on: July 10, 2007, 03:29:46 am »
Hi i bump this instead of makeing a new one.
on my engine, don't know if its a 1v or jr but when staning in front of it on right side at a waterhose i got a temp sensor witch has no cables in, and above that on the top i also has something that can remind me of oil pressure switch, still no cables.. What are those for? The last ower said the engine was changed. looking at this thread a guy told me i got the ECO diesel. But i'm worried what those are for.
And now, when i got the car the temp sensor inside the car didn't work, after just looking around with my hands it suddenly started to work and i didn't connect any cables. It went almost to half when driving, now it won't go past the first white what can cause this? And where is the sensor, is it on the hose at the fron of the engine with 2 plugs/sensors?
My tacometer acting strange, where does it read rpms from, my alternator?
Reply #7July 10, 2007, 12:56:30 pm
« Reply #7 on: July 10, 2007, 12:56:30 pm »
Yes tach gets its signal from the alt. A poor connection is the usual problem.
Can you get a picture of your engine?
