possible to use 1.9 pistons?
Topic: possible to use 1.9 pistons? (Read 2100 times)
June 23, 2007, 01:35:03 pm
the4ork
June 23, 2007, 01:35:03 pm »
is it possible to bore the block out the much, reliably? with the 1.6 block
June 23, 2007, 01:48:17 pm
subsonic
June 23, 2007, 01:48:17 pm »
No.
1.7 piston, yes. However wall thickness will become a very real concern.
Do a search for 1.7 . There is a long discussion on this conversion, pro's con's etc...
It would be nice though.
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
June 23, 2007, 06:10:00 pm
the4ork
June 23, 2007, 06:10:00 pm »
what about the 2.5 pistons?
June 26, 2007, 06:52:42 am
DA-BRT
June 26, 2007, 06:52:42 am »
I've ordered one Mahle 1.8TD piston. To see If I can make that one work in my new 1.9 future engine.
I've been searching for a lot of pistons for my actual engine. It's also a Mahle piston. For the KY 1700d engine. Only designed the same as the 1.6TD pistons. With a thicker head and opening for the oil squirter.
Now I got a 1.7D. For now. I'm now bussy with a VGT exhaust manifold. So I can place the KKK VGT turbo (3.0TDI A6 2007)
Greetz.
Bert
-=<To>=-
For sale:
M-TDI pumps 12mm (Prepared for VAG TDI engines)
