Author Topic: Golf III IDI  (Read 2737 times)
July 05, 2007, 09:28:02 pm
OM617
Golf III IDI
« on: July 05, 2007, 09:28:02 pm »
I have heard that these are quite rare, only available for 3 months before the TDI was introduced.  Was the Golf III IDI even sold in America?
I need to get a set of injectors from one.
Reply #1July 05, 2007, 10:01:49 pm
ezekiel
  • 147
Golf III IDI
« Reply #1 on: July 05, 2007, 10:01:49 pm »
US Golf III = TDI only
Canada Golf III = AAZ (IDI) and TDI
all of which were 1.9L TD motors.
Reply #2July 05, 2007, 11:45:23 pm
OM617
Golf III IDI
« Reply #2 on: July 05, 2007, 11:45:23 pm »
Ah, turns out it was a miscommunication in another forum.
I thought they had a larger internal volume than the stock MB injectors.
Here is the quote from the other forum.
The VW double spring injectors do not have larger internal volume, sorry for the misunderstanding. The nozzles have to be replaced in the original VW ones by 265 or 261 nozzles (used in 60x engines).
Advantage: Way smoother, diesel-like start with wvo, less smoke.
They should not be used with the original 308 nozzles because those will eat up the pre glow sticks. VW does not use the pre chamber system with the ball.
The part number is: VW 028 130 201B or BOSCH 2FH KCA 27 S 77
The engine is 1.9 TurboDiesel (not TDI) engine AAZ. IIRC, from 92-93.
Tom
