Author Topic: 3.67 Final drive on a 1.6TD  (Read 5687 times)
July 03, 2007, 07:53:23 pm
« on: July 03, 2007, 07:53:23 pm »
I recently read a post about a guy who had a 3.67 final drive in his 1.6 and absolutly hated it. He said his car was a total dog.
Is anyone running this setup?
I was thinking of getting an ASF and swapping in a 0.71 fifth. I know it's a fairly big jump from 4th to fifth. Ideally I'd love to get a DFP with the .091 fourth but I don't have one in my inventory
Reply #1July 03, 2007, 08:04:55 pm
foxracer1
  • 991
« Reply #1 on: July 03, 2007, 08:04:55 pm »
Thats awesome you have inventory. i wish i had VW inventory.  :wink:
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #2July 03, 2007, 08:33:13 pm
935racer
« Reply #2 on: July 03, 2007, 08:33:13 pm »
ASF is with a swapped in .71 5th is hands down my favorite o2o gearbox to run in a td. I doubt it would be a dog even stock, it definitely is not a dog the way I set up my motors.
Reply #3July 03, 2007, 08:36:50 pm
« Reply #3 on: July 03, 2007, 08:36:50 pm »
Wonderful, thanks Dave :D
Yeah it's great having an endless supply of parts :lol:
Reply #4July 04, 2007, 08:52:08 pm
ODwyerPW
  • 103
    • http://www.Espanglish.com.mx
« Reply #4 on: July 04, 2007, 08:52:08 pm »
I too would love the 3.67 Final Drive and the .71 fifth.
83 Rabbit LS Turbo Diesel
Reply #5July 04, 2007, 09:26:27 pm
ezekiel
  • 147
« Reply #5 on: July 04, 2007, 09:26:27 pm »
you think that tranny could take a TDI?  Not being raced or beat on, but boosting to around 18psi max (probably 8-10 daily) ?
Reply #6July 05, 2007, 03:33:50 am
stewardc
« Reply #6 on: July 05, 2007, 03:33:50 am »
My new tranny, for use with the AAZ Torquemonster is a DFP with 3.67 and .71. I'm looking for great things on the top end... :wink:
Reply #7July 05, 2007, 05:03:53 am
« Reply #7 on: July 05, 2007, 05:03:53 am »
The DFP is what I wanted but at $400 I decided to pass and build my own. I think I have 2 extra 0.71 gear sets that I'll sell when I get to that
ezekiel If you aren't doing any sudden torque loading it should be fine. Get a bolt kit for the diff though
Reply #8July 05, 2007, 02:27:53 pm
foxracer1
  • 991
« Reply #8 on: July 05, 2007, 02:27:53 pm »
I have a FN 3.89/ .71 and the N/a would like a little more rpm on the highway around 60-70mph. But if i had a little boost it would pull great. Plus my tires are a little taller than the factory ones.
91 S10 305 TPI T56
Reply #9July 05, 2007, 04:02:38 pm
rabbit GTI/GTD
  • 58
« Reply #9 on: July 05, 2007, 04:02:38 pm »
I'm running a tranny code CHD, which is a 3.67 final with a .75 fifth, in an MK3 golf with a high mileage 1.6TD, and i dont find it to bad at all, i like the ratio better than the one i had in the jetta the engine came from it was a 3.94 final, with all the same gear ratios 1st through 5th.
Reply #10July 05, 2007, 05:38:48 pm
« Reply #10 on: July 05, 2007, 05:38:48 pm »
I have an FN tranny with 3.89 final and .71 fifth. With stock tires the motor turns 3000RPM @70MPH. I wonder if a 3.67/.71 in a NA rabbit would be to high geared? You'd have to down shift as soon as the car saw a hill but whats knew? :shock:
Reply #11July 06, 2007, 08:38:08 am
Darth Garry
  • 136
    • http://www.notinteresting.com
« Reply #11 on: July 06, 2007, 08:38:08 am »
I've been running FN for years, and love it.  A nice tall fifth is just what the doctor ordered for my purposes.  In N/A it didn't like the hills, but with a turbo it was mint.
Garry
All for one, and one for Awesomeness!
Reply #12July 06, 2007, 10:18:10 am
larry104
  • 200
Re: 3.67 Final drive on a 1.6TD
« Reply #12 on: July 06, 2007, 10:18:10 am »
Quote from: "burn_your_money"
I'm running a 3.67 differential with a .71 5th gear in a 1992 1.6 TD. See the post "My 1992 Ecodiesel is done." The car was originally an Ecodiesel (N/A pump) with a 4.25 differential and a .75 5th gear. It was absolutely miserable to drive on the highway. Now, I can comfortably run 75-80 mph. And there's plenty of power to pull the taller gearing around the city. [/i]
Reply #13July 06, 2007, 12:11:30 pm
foxracer1
  • 991
« Reply #13 on: July 06, 2007, 12:11:30 pm »
A friend of mine put his ECO trans behind his gasser and it was a much better match for the gasser powerband. he plans to put a FN with the 3.67 final when his project is completed.
I agree my car would be great with boost h n/a dosen't like the hills.
91 S10 305 TPI T56
Reply #14July 06, 2007, 08:48:41 pm
« Reply #14 on: July 06, 2007, 08:48:41 pm »
ah i cant wait to install my CHE with a 0.71 5th w/3.67 final...
78mph @ 3000rpm! Yesss!! (i know... TDI trannies are so much better, but AHA! it comes with a PELOQUIN!!!)
