Author Topic: Making more power from a 1.6 non turbo  (Read 2463 times)
June 24, 2007, 12:38:46 pm
jarrodback
  • 1
« on: June 24, 2007, 12:38:46 pm »
Hello all, I am new to this forum, and new to an IDI car.  I have just purchased an '82 caddy with a 1.6L non turbo.  It seems that most of the discussion here is about TD's.  What can I do to make  more power from my current motor.  I am willing to turbo charge it if that isn't too expensive.  Or are there other mods that would be better/economical, etc.  etc.  Also is there a good source for parts that someone could provide.  Thanks in advance for any and all of your help.
Jarrod Back
_____________
'02 TDI Jetta- pp520's, Rocket Chip, G60 flyweel, VR6 clutch, etc., etc.
'80 Caddy diesel
'83 RX-7
Reply #1June 24, 2007, 04:43:01 pm
« Reply #1 on: June 24, 2007, 04:43:01 pm »
A turbo kit will cost you less then $500 shipped to your door
If you have a toilet bowl style exhaust get a 4:2:1 setup. Also make the rest of the exhaust as big as possible. Since you don't have a turbo you will probably want 1 muffler.
New/rebuilt injectors, proper timing, half the gov mod and a couple turns of some screws on the pump will get you moving faster.
You should add your location to your profile
Reply #2June 24, 2007, 09:09:16 pm
dieselsnowmobile
  • 103
« Reply #2 on: June 24, 2007, 09:09:16 pm »
Be varefully how much boast you run on a NA block without oil squirters underneath the pistons.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #3June 25, 2007, 03:35:05 pm
bevboyy
  • 200
« Reply #3 on: June 25, 2007, 03:35:05 pm »
Big must haves if running a turbo on a n/a:
Intercooler
External air/oil cooler - not the stock coolant/oil cooler..
EGT gauge
I would not run anything past 15 psi intercooled.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #4June 26, 2007, 06:31:35 am
  • 1156
    • Malone Tuning Ltd.
« Reply #4 on: June 26, 2007, 06:31:35 am »
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
