Author Topic: Injection pump upgrade. Which one ?  (Read 4071 times)
August 31, 2004, 07:32:21 am
neich
  • 28
« on: August 31, 2004, 07:32:21 am »
Hi,
I have a T3 vanagon with a 1.9TD (AAZ) engine swapped in. It still has the old 1.6TD (JX) turbo and injection pump. The last one has 250K km on it, and it seems it is starting to fail. I can rebuild it, or install an AAZ pump. Browsing ETKA I have found that there are several injection pumps that were used with the AAZ. Which one is the best ?
Thanks
Nacho
Reply #1August 31, 2004, 08:23:01 am
caddy
  • 748
Re: Injection pump upgrade. Which one ?
« Reply #1 on: August 31, 2004, 08:23:01 am »
Quote from: "neich"
Hi,
Thanks
Nacho
if you fit a aaz pump be carful ! because some of them don't have lda corrector inside! and outside it seems to be ok...
then if you have a good pump, you need to change some part for best performance.
