Author Topic: Boost Pin?  (Read 3936 times)
September 13, 2004, 10:29:55 pm
WishIHadaRabit
  • 37
Boost Pin?
« on: September 13, 2004, 10:29:55 pm »
I got a boost pin from a 1.6l td pump and was going to install in my '95 td pump but the pin was loose in the 1.9l pump housing. Is this normal :?:
Reply #1September 14, 2004, 06:55:44 pm
Wingaman
  • 7363
    • http://www.dmfdiesel.com
Boost Pin?
« Reply #1 on: September 14, 2004, 06:55:44 pm »
Try it, if is smoking like the hell you will know why.
Did you used the spring and the cover of the 1.6TD pump on your 1.9TD pump ?
I think you should use the LDA cover from the 1.6TD pump to be capable tu adjust the "no boost" delivery (smoke adjusting screw on the top)
But for the spring i dont know witch one is the best.
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
Reply #2September 16, 2004, 09:30:42 am
WishIHadaRabit
  • 37
Boost Pin?
« Reply #2 on: September 16, 2004, 09:30:42 am »
The spring perch in not the same The 1.6 spring is too short.
Measured the pin diameters and my 1.9 pin is a little more then 1mm bigger.
I don’t think I’ll try it.
At least not until I get the other turbo on there.
I’ll try to find another pin to see if it’s the same.
As anybody out there measured there pin?
