Author Topic: Pump timing range  (Read 3425 times)
September 12, 2004, 03:45:59 pm
RedRotors
  • 734
    • http://www.mikrotuning.com
Pump timing range
« on: September 12, 2004, 03:45:59 pm »
Hi guys,
I would like to know ( probably a question for Giles ) what's the timing range of a 1.6TD pump. I mean, when the car run at idle, how much degree BDTC fuel is injected and how much when the timing piston in the fuel pump reach max travel distance..
TIA,
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #1September 12, 2004, 10:41:25 pm
fspGTD
  • 1529
Pump timing range
« Reply #1 on: September 12, 2004, 10:41:25 pm »
Jake Russell
Reply #2September 13, 2004, 04:11:34 am
RedRotors
  • 734
Pump timing range
« Reply #2 on: September 13, 2004, 04:11:34 am »
Thanks Jake!  :wink:
Marc/
91' VW Golf Country
-> www.hflox.com <-
