Author Topic: 33MPG!?!? WHat gives??  (Read 6459 times)
August 11, 2004, 12:26:59 pm
Angry Tape
« on: August 11, 2004, 12:26:59 pm »
ALright....I didnt bother checking how bad the MPG was when I had the close ratio gear box in her but I put an FN code tranny in her, filled her up, and am now almost empty.  Looks like im going to end up getting about 32 MPG on this tank of Diesel.  That is entirely unacceptable. THe motor is a fresh rebuild (1.6l TD, has about 2000 miles on her now), power seems good, the vavle shims were all redone....what gives?  My dad seems to think that the pump is a piece.  Im thinking that ill try readjusting the timing (she smokes a little bit) and keeping my foot off the pedal a little more.
Any other suggestions?  I used to get 52mpg out of my 86 N/A golf and about 43-44 out of my 83 TD jetta.
Also....Ive got another TD pump that needs to be rebuilt.  Anyone that you guys recommend?
Reply #1August 11, 2004, 12:33:18 pm
BlackTieTD
  • 1512
« Reply #1 on: August 11, 2004, 12:33:18 pm »
alignment? wheel bearings? tires?
how heavy are you on the throttle?
is that all city driving?
what chassis is this?
keeping it in 5th when cruising helps a lot.. but you got good milage with the other two cars... i assume your driving habits are similar?
Reply #2August 11, 2004, 04:28:41 pm
Dr. Diesel
  • 1341
« Reply #2 on: August 11, 2004, 04:28:41 pm »
odometer accurate?
Reply #3August 11, 2004, 09:20:00 pm
Angry Tape
« Reply #3 on: August 11, 2004, 09:20:00 pm »
The car is basically new.  Everything in the front end has been replaced.  Its an 84 Rabbit.  Driving habbits are the same in the jetta as in the rabbit.  Mostly Highway.  From what I can tell the odometer is correct.
Any other ideas?  33mpg sucks  :(
Reply #4August 12, 2004, 12:28:57 am
Cheesetoast
  • 285
« Reply #4 on: August 12, 2004, 12:28:57 am »
change the tranny fluid? air filter? check the brakes.
Reply #5August 12, 2004, 04:22:24 am
addautomotive
« Reply #5 on: August 12, 2004, 04:22:24 am »
If I was a bettin' man, I'd put my money on brakes. I recently saw an increase of approx 75 km/ tank after doing a bunch of brake work. I figure it was either the calipers or emergency brake cables.
Reply #6August 12, 2004, 08:25:32 am
BlackTieTD
  • 1512
« Reply #6 on: August 12, 2004, 08:25:32 am »
good. i need to do a brake job and i'm still hoping to pick up a few MPG. ..need to change gearbox fluid as well..
Reply #7August 12, 2004, 04:19:22 pm
Dr. Diesel
  • 1341
« Reply #7 on: August 12, 2004, 04:19:22 pm »
Both my diesel rabbits odometers are not accurate. Speedos either.  Stock size wheels. Based on driving next to a caddy with a digital spedometer, and the highway KM markings.
Reply #8August 12, 2004, 10:11:49 pm
Angry Tape
« Reply #8 on: August 12, 2004, 10:11:49 pm »
Like I said....everything is new...including the brakes.  :D   I just changed the tranny fluid tonight over to synthetic..not becasue of better MPG...cause I was ready to swap.  I doubt that will have any significant effect.
Reply #9August 13, 2004, 10:47:44 am
BlackTieTD
  • 1512
« Reply #9 on: August 13, 2004, 10:47:44 am »
next thing i would do is drive along with a friend with a known-to-be-good odometer.... or drive a confirmed distance... and check and see what the odo tells you. its proberly off, wouldn't be the 1st time.
Reply #10August 18, 2004, 05:51:37 pm
chrissev
  • 694
Re: 33MPG!?!? WHat gives??
« Reply #10 on: August 18, 2004, 05:51:37 pm »
Quote from: "KarmannSport"
A TD shouldn't smoke.  Perhaps your injectors are bad.
