Author Topic: Any info on this pump?  (Read 4163 times)
August 23, 2004, 02:19:42 pm
GTDi
  • 6
« on: August 23, 2004, 02:19:42 pm »
0460 494 346 Bosh
I think they are the correct numbers...
VW Golf GTDi
VW Corrado G60
Mitsubishi Pajero TDi
Reply #1August 23, 2004, 02:55:44 pm
RedRotors
  • 734
    • http://www.mikrotuning.com
« Reply #1 on: August 23, 2004, 02:55:44 pm »
This pump has been use for the 1.9 TD engine in VW Golf,Vento mk3. From 1991 to 1999. 55kw. Bosch formula : VE4 /9F2300R433-2
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #2August 24, 2004, 02:28:26 pm
GTDi
  • 6
« Reply #2 on: August 24, 2004, 02:28:26 pm »
Thx about the info Marc, you know if the driveshaft is 17mm or 20mm?
VW Golf GTDi
VW Corrado G60
Reply #3August 24, 2004, 02:32:21 pm
RedRotors
  • 734
« Reply #3 on: August 24, 2004, 02:32:21 pm »
I don't know if the pump got the big shaft, but my feelings tell me yes.. The "-2" in the Bosch formula is for the second generation of pump.. But to be sure, you will have to take a look at it..
Marc/
91' VW Golf Country
-> www.hflox.com <-
