Author Topic: Glow plug fusible link on firewall  (Read 5043 times)
September 15, 2004, 02:06:12 pm
farkman
  • 172
« on: September 15, 2004, 02:06:12 pm »
Hey guys
This morning my car took longer to start than normal. When I got home, I checked that little fusible link that is on the firewall and found that it was broken. I was wondering if I could use a small piece of brass shim stock  instead because it's the only metal I have which is really thin. Would this work or should I get the proper fuse.
Thanks
Reply #1September 15, 2004, 06:34:27 pm
RedRotors
  • 734
    • http://www.mikrotuning.com
« Reply #1 on: September 15, 2004, 06:34:27 pm »
You should get the right fuse for it.. It cost a few coins at the stealer..
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #2September 16, 2004, 04:21:35 am
Jetta Jockey
  • 14
« Reply #2 on: September 16, 2004, 04:21:35 am »
When the fusible link broke on my car, I moved the wire over to the other side's terminal ( :shock: not a recommended longterm fix :shock: ) until I got a new one and a spare at my local VW specialty parts haus.
Steve
'05 Golf GLS TDI-PD 8)
'91 1.6NA (Foul Weather Car);)
Reply #3September 16, 2004, 04:33:32 am
farkman
  • 172
« Reply #3 on: September 16, 2004, 04:33:32 am »
Thank for the responses guys. I put a small piece of .010 brass shim stock on yesterday and the problem was fixed. I'll go to the dealership next week some time and pick up a few proper fuses.
Peter
Reply #4September 16, 2004, 09:58:15 am
DieselsRcool
  • 152
« Reply #4 on: September 16, 2004, 09:58:15 am »
This fuse being blown may be an indication of a bad glowplug. Just keep this in mind if it starts harder than usual when cold.
Reply #5September 16, 2004, 01:20:15 pm
farkman
  • 172
« Reply #5 on: September 16, 2004, 01:20:15 pm »
DieselsRcool
The fuse wasn't blown, it just broke in half. It was corroded which probably weakened it, so I think that's why it broke.
Reply #6September 16, 2004, 03:33:55 pm
fspGTD
  • 1529
« Reply #6 on: September 16, 2004, 03:33:55 pm »
Make sure you've got washers between the glow plug fuse and it's hold-down bolts.  Otherwise when you tighten the hold-down bolt, it twists the thin delicate fuse material, which can cause it to crack.
Jake Russell
Reply #7September 16, 2004, 04:20:36 pm
VWRacer
  • 649
« Reply #7 on: September 16, 2004, 04:20:36 pm »
Quote from: "fspGTD"
Sounds like the voice of experience... :wink:
Stan
C-Sports Racer
Reply #8September 16, 2004, 05:07:59 pm
farkman
  • 172
« Reply #8 on: September 16, 2004, 05:07:59 pm »
fspGTD
I got washers between the bolts and the fuse. I sanded the washers as well, because they were corroded, to make sure there was a good connection.
