Author Topic: GTD into a corrado?  (Read 1949 times)
August 09, 2009, 07:01:45 pm
54321chris
GTD into a corrado?
« on: August 09, 2009, 07:01:45 pm »
A friend of mine has a G60 corrado project (bilstein pss9, wilwood brakes, 4pt roll cage) that I'm thinking about dropping my 1.6 gtd into.  From what I gather, the corrado is a couple hundred pounds heavier than my mk2 jetta sedan that the motor is currently in (still trying to work out wiring issues).  Is it going to be any more of a nightmare trying to get the corrado gauges to work than it is in the jetta?  I'm a total electrical newb...  The corrado currently has a 2.0 with a t3 turbo, but not wired yet.  Not sure of the exact specs on the turbo, but I'm curious what you all think about whether I should keep the t2 I currently have or use the t3 on the gasser motor.  I'll be dd'ing it if I do the switch, so driveable power is what I'm looking for, not something that I have to run up to 4500 before I see much boost.  Any general comments on this whole swap idea? I guess I'd use the transmission currently in the g60, since it's cable shift.
