Author Topic: AAZ Build Up  (Read 2616 times)
August 07, 2009, 05:40:43 pm
Garrett
  • 26
AAZ Build Up
« on: August 07, 2009, 05:40:43 pm »
Hi everyone!
I picked this Jetta up last summer as a daily driver, it was stock for awhile, now it's slowly turning into another project car...  :lol:
As it sits today:
Vmaxx Coils
15" Corrado Steelies
GTI Smoked Dual Chamber E-codes
GTI VR6 Seats
GLX Taillights
European Black Emblems
I've decided to perk the motor up a little bit, and therefore I am waiting on some parts and then I will get to work. This is what I've ordered:
- ACT 6 Puck Sprung Clutch
- 16V Pressure Plate
- New flywheel
- ARP Headstuds
- Block gasket set
- Head gasket set
- Transmission input shaft seal
- Pushrod seal and bushing
- Timing belt and tensioner
I will be freshening up the engine with new gaskets and seals, as well as with the transmission. The stock k03 turbo will be replaced with a 1.6 Garrett T3 and I will be welding up a 2.5" turbo back exhaust. I can't really afford a Giles pump yet (being in school), so I'm building everything so it will be ready for it when the time comes. It should still be a quick little car even without the pump. I also have a Corrado intercooler I may use... haven't decided yet.
One quick question, I've been told I should leave the headgasket alone and just install the ARP studs one at a time. I've built a few gas VW motors before and replacing the headgasket while it was apart would go without question. Because of this I'm a little weary of just leaving it be.
I'll update some more when the motor comes out!
-Garrett
'90 Golf PG Turbo - Money hungry dirty whore.
'97 Jetta TD - For the rainy days.
'00 Jetta VR6 - Long gone.
'99 Kawasaki ZX9R - For Sale!
Reply #1August 08, 2009, 04:21:47 pm
Garrett
  • 26
Re: AAZ Build Up
« Reply #1 on: August 08, 2009, 04:21:47 pm »
Anyone have any advice for the headgasket?  :)
Reply #2August 08, 2009, 04:52:09 pm
Re: AAZ Build Up
« Reply #2 on: August 08, 2009, 04:52:09 pm »
Metal :D
Badass car YO!
Reply #3August 08, 2009, 05:15:55 pm
catlin_cava
  • 1954
Re: AAZ Build Up
« Reply #3 on: August 08, 2009, 05:15:55 pm »
That is one Nice car.
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #4August 08, 2009, 06:48:01 pm
Re: AAZ Build Up
« Reply #4 on: August 08, 2009, 06:48:01 pm »
Go with a MLS gasket. If I were you I would wait until the stock bolts give it up adn you have to het a head gasket.
Reply #5August 08, 2009, 07:02:09 pm
Garrett
  • 26
Re: AAZ Build Up
« Reply #5 on: August 08, 2009, 07:02:09 pm »
I would definitely be replacing it with the AAZ MLS gasket (another one hole)... but what are the chances that the head would be no good if I were to take it off and do everything at once? The motor has 255000 km on it now. I would much rather do it all at the same time while I have the motor out; but if I were to possibly need a new head, now would not be the time (funds are tight). What are your guys' experience with this?
Thanks!
Reply #6August 09, 2009, 08:50:37 am
farkman
  • 172
Re: AAZ Build Up
« Reply #6 on: August 09, 2009, 08:50:37 am »
Taking the head off won't hurt it. I recently replaced the head on my AAZ since the swirl chamber cracked and bounced around in the cylinder. My head has 280k km and the one I replaced it with had 270k km. All I did was stone the surface of it to get it smooth and relatively flat. It's been working great for the past 2000 km.
While you got the engine apart I would recommend you check the crank gear and get a new bolt as well. For head gaskets, Victor Reinz makes a sweet metal one.
Reply #7August 09, 2009, 01:47:41 pm
Garrett
  • 26
Re: AAZ Build Up
« Reply #7 on: August 09, 2009, 01:47:41 pm »
I may as well go ahead and replace it!
Reply #8August 09, 2009, 06:06:53 pm
Pillow
  • 17
Re: AAZ Build Up
« Reply #8 on: August 09, 2009, 06:06:53 pm »
Beautiful ride!
WTB/T:  MK1 Jetta Coupe for IDI 1.9 conversion
FS:  '99 Suburban 6.5TD K2500, '79 Porsche 911SC, '57 Oval Beetle Project
Sold: '66 Westi 2.0L w/ Turbo and CIS
Keepers: '96 Sierra 6.5TD K3500, '71 C-10, '48 Spartan Manor trailer
"Boost gets you laid!"
