Cold Start Cable Problem
Topic: Cold Start Cable Problem (Read 2063 times)
August 07, 2009, 12:47:30 pm
Garrett
User+
August 07, 2009, 12:47:30 pm »
Hey guys,
I seem to be having an issue with the cold start cable in my '97 AAZ Jetta. I can pull it out no problem and it moves the lever on the back of the pump; but when I push the handle back in, the lever doesn't reset and I have to push it back with a screwdriver. Any ideas?
Thanks!
'90 Golf PG Turbo - Money hungry dirty whore.
'97 Jetta TD - For the rainy days.
'00 Jetta VR6 - Long gone.
'99 Kawasaki ZX9R - For Sale!
August 07, 2009, 01:26:15 pm
Re: Cold Start Cable Problem
August 07, 2009, 01:26:15 pm »
I bet the clip fell off the housing on the back of the pump. Either that or the housing is no longer held solid on the knob end.
August 07, 2009, 01:40:29 pm
Garrett
User+
August 07, 2009, 01:40:29 pm »
I will take a look at both! Thanks!
August 08, 2009, 03:42:35 am
Zulfiqar
August 08, 2009, 03:42:35 am »
or someone put the clip before the grommet
Diesel IS the future
August 08, 2009, 08:42:00 pm
August 08, 2009, 08:42:00 pm »
I've said this a lot in life, but you can never try enough LUBE.
