Author Topic: Where can you buy heat shields?  (Read 2681 times)
August 07, 2009, 03:09:27 am
truckoSaurus08
  • 65
« on: August 07, 2009, 03:09:27 am »
 Like the subjects says, I seem to be having trouble find these in my local area (utah) and the places ive been to all seem think the old ones are re-usable, including bosch dealers. Dealership around here don't sell any parts older than 15 years. Are TDI heat shields the same? Or what about Prothe? Those any good?
Thanks for any advice
Reply #1August 07, 2009, 03:56:31 am
Reply #2August 07, 2009, 02:48:35 pm
Re: Where can you buy heat shields?
« Reply #2 on: August 07, 2009, 02:48:35 pm »
TDIs use copper washers, completely different. I wouldn't trust anything but OEM. Not that it's a very high precision piece but if it doesn't perform as required it will overheat your injector and could clog the injector area up with carbon making it very difficult to remove, which in a worse case scenario would crack the injector boss when you try and take the injector out
Reply #3August 07, 2009, 03:13:41 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #3 on: August 07, 2009, 03:13:41 pm »
Didn't Mercedes used the same shields for those 1970's panzers? 8)
Reply #4August 07, 2009, 04:56:15 pm
truckoSaurus08
  • 65
« Reply #4 on: August 07, 2009, 04:56:15 pm »
Thanks! I was working and i had a sudden realization that tdi's don't have the pre-chamber like the idi so they probably don't even have that style heat shield. So please excuse that absent minded question. ::)
Yeah good thing theyre cheap, I'll buy plenty of extras.
Also, I found a good way to remove the heat shields. What you do is get a coat hanger bend it the very tip ( just enough so it passes through the hole but snags when you pull it. Put a big socket on it and you've got yourself a slide hammer! Worked pretty damn good. Hope that contributes something.
Reply #5August 08, 2009, 03:37:14 am
Zulfiqar
  • 254
« Reply #5 on: August 08, 2009, 03:37:14 am »
yep mercedes IDI engines use the same heat shield just the hole is larger in it
Diesel IS the future
