Author Topic: crack in block?  (Read 2636 times)
August 11, 2009, 03:21:26 pm
vwjones
  • 80
crack in block?
« on: August 11, 2009, 03:21:26 pm »
i have an mk1 with an oil drip and it seems to be coming from the bolt hole that holds the passenger side motor mount.  does the bolt go thru to the enginge?  doesn't sound possible to me.  i didn't torque it down like an idiot and i'm sure I didn't crack it.  any ideas?
Reply #1August 11, 2009, 07:14:55 pm
rabbid79
  • 684
Re: crack in block?
« Reply #1 on: August 11, 2009, 07:14:55 pm »
I'm not extremely familiar with the 1.6 engines, but enough so not to think it goes all the way into the inside of the block.
'15 WRX
Reply #2August 11, 2009, 10:31:22 pm
Re: crack in block?
« Reply #2 on: August 11, 2009, 10:31:22 pm »
the motor mount that is the injection pump bracket too? yea, those are held on my a whole bunch of bolts. but its probably just a cam seal.
Reply #3August 11, 2009, 11:46:54 pm
maxfax
  • 2126
Re: crack in block?
« Reply #3 on: August 11, 2009, 11:46:54 pm »
I just examined my squekay clean block I got back from the machie shop today  ;D..   If you cracked one of those bolt holes you'd be leaking water before oil..  Probably a cam seal like Rabbit on Roids mentioned...
Reply #4August 12, 2009, 01:40:58 am
vwjones
  • 80
Re: crack in block?
« Reply #4 on: August 12, 2009, 01:40:58 am »
thanks guys...it's always something with these cars :(
Reply #5August 12, 2009, 02:02:49 am
maxfax
  • 2126
Re: crack in block?
« Reply #5 on: August 12, 2009, 02:02:49 am »
I get scared when there isn't.......
Reply #6August 12, 2009, 09:27:59 am
arb
Re: crack in block?
« Reply #6 on: August 12, 2009, 09:27:59 am »
Yeah, there's water on the other side of those bolts... and the head's oil pressure passage is more than half way to the over side of the block.
