toyota td
Topic: toyota td (Read 2540 times)
October 16, 2008, 12:12:01 pm
garagebandboy
Newbie
toyota td
October 16, 2008, 12:12:01 pm »
does anyone know if a toyota td injector pump works on a 1980 vw rabbit diesel?
Dave
October 16, 2008, 12:22:53 pm
toyota td
October 16, 2008, 12:22:53 pm »
I don't think it will or it wont run properly.
I have a Toy pump at home and the cam plate in it is WAY different then the VW cam.
I didn't really see a difference in the internals other than that.
October 16, 2008, 03:13:52 pm
toyota td
October 16, 2008, 03:13:52 pm »
Depending what motor it's for, it's more then likely going to overfuel the car and you'll have black smoke, hanging RPMs and all sorts of other fun stuff.
What's wrong with your pump?
October 16, 2008, 03:29:31 pm
toyota td
October 16, 2008, 03:29:31 pm »
It's still a little 8mm pump and the cam plate doesnt have as much lift as the VW cam.
Or at least the one I have is.
It came off a 84 Toyota 2.4ltr.
October 18, 2008, 11:00:06 am
garagebandboy
Newbie
toyota td
October 18, 2008, 11:00:06 am »
i'm looking to turbo my n/a rabbit
Dave
October 20, 2008, 08:08:46 am
toyota td
October 20, 2008, 08:08:46 am »
Until you get a true TD pump I would just go ahead and turbo it with your Na pump.
October 20, 2008, 12:07:36 pm
garagebandboy
Newbie
toyota td
October 20, 2008, 12:07:36 pm »
how much more power can i get without a true td pump
Dave
October 20, 2008, 01:05:50 pm
toyota td
October 20, 2008, 01:05:50 pm »
Quite a bit. To the point you should add an EGT gauge as well to make sure you don't get it to toasty.
What you will find is it will smoke off idle until the turbo spools up at that point the smoke will clean up.
OR you can turn the pump down so it doesn't smoke off idle but it sure wont be as fun to drive.
toyota td
