Author Topic: return line  (Read 2355 times)
October 10, 2008, 06:17:33 pm
garagebandboy
  • 15
return line
« on: October 10, 2008, 06:17:33 pm »
i put clear fuel line between the injectors and i noticed lots of air bubbles in them. would it be okay to plumb the return line through the injectors?
Dave
Reply #1October 10, 2008, 06:21:49 pm
autoholic
return line
« Reply #1 on: October 10, 2008, 06:21:49 pm »
I think it would be too restrictive to send all return fuel through the injectors. Interesting thought though.
Reply #2October 11, 2008, 01:42:04 pm
garagebandboy
  • 15
return line
« Reply #2 on: October 11, 2008, 01:42:04 pm »
what if i made it so it would flow out of both the return line and the injectors. instead of blocked off at the last injector?
Dave
Reply #3October 11, 2008, 08:35:32 pm
return line
« Reply #3 on: October 11, 2008, 08:35:32 pm »
Quote from: "garagebandboy"
sounds like a bit more lines than you'd want to me.  are you trying to achieve no bubbles or something???  i dont think that this will fix that problem.  how does it run?
Reply #4October 11, 2008, 09:44:35 pm
Jet A
  • 125
return line
« Reply #4 on: October 11, 2008, 09:44:35 pm »
not that you need a reason, but why?
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #5October 12, 2008, 12:02:33 am
garagebandboy
  • 15
return line
« Reply #5 on: October 12, 2008, 12:02:33 am »
just because i'm trying to get from 0-60 faster then 25 sec.
Dave
Reply #6October 12, 2008, 09:13:18 am
shegel
  • 312
return line
« Reply #6 on: October 12, 2008, 09:13:18 am »
giles pump .....or impossible....or just go down a big hill
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #7October 14, 2008, 08:53:40 pm
garagebandboy
  • 15
return line
« Reply #7 on: October 14, 2008, 08:53:40 pm »
how much does it cost? i'm thinking of turbocharging
Dave
