Those of you who have made a new oil return line
Topic: Those of you who have made a new oil return line (Read 2430 times)
October 13, 2008, 05:30:37 am
allsierra123
October 13, 2008, 05:30:37 am »
What did you make it out of? Does it matter? Or does it have to be braided stainless? Any pics?
October 13, 2008, 05:35:23 am
TurboJ
October 13, 2008, 05:35:23 am »
Heat can be an issue. Make sure it'a heat-resistant material.
Jetta II 1.6 TD 'Project 200'
October 13, 2008, 06:34:19 am
dillenger1
October 13, 2008, 06:34:19 am »
1.6td in toyota pickup
10mm head ,t3 intercooled.
October 13, 2008, 06:35:10 am
dillenger1
October 13, 2008, 06:35:10 am »
October 13, 2008, 07:12:43 am
Jet A
October 13, 2008, 07:12:43 am »
I used fuel hose from napa, good to 300f or so. where is the other end of your return going, block or pan?
Brass on steel can be tricky. make sure you use a good teflon tape or paste. otherwise, the expand and contract will cause leaks
85 vw golf NA ----> 2b TD Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
October 13, 2008, 07:55:24 am
53 willys
October 13, 2008, 07:55:24 am »
I bought some steel -AN fittings..I cut them off and welded them to a old drain pipe...then I cut the metric threads off the oil pan and welded -AN fittings on there too...I used braided stainless hose...wrapped in a protector.
October 13, 2008, 08:09:51 am
dillenger1
October 13, 2008, 08:09:51 am »
[/quote]Brass on steel can be tricky. make sure you use a good teflon tape or paste. otherwise, the expand and contract will cause leaks[/quote]
i jb welded the seal.I noticed the change when i welded it to the manifold.I did it cold as i could.
October 13, 2008, 09:00:48 am
Jet A
October 13, 2008, 09:00:48 am »
JB for president!!!!
Nice work!
October 13, 2008, 02:29:18 pm
autoholic
October 13, 2008, 02:29:18 pm »
I used "abrasion king" low psi hydraulic hose (I think its Gates), it works with hose barbs and was an easy way to go. For the supply I bent up 5/16 steel line. I ended up running the drain to the block,
I did not want any fittings down low and did not want to deal with welding in a fitting.
