Author Topic: 1995 jetta coolant gasket  (Read 1907 times)
October 20, 2008, 08:02:26 pm
gunrtd
  • 31
« on: October 20, 2008, 08:02:26 pm »
what is the name of the gasket that is under the housing which connects the upper rad hose to the cylinder head? The housing looks plastic. Looks like a thermostat housing.
Any one have a FelPro PN#?
Reply #1October 20, 2008, 09:16:21 pm
Quantum TD
  • 1195
« Reply #1 on: October 20, 2008, 09:16:21 pm »
Chances are, if that seal is leaking, you need a whole new housing. The housings are in fact plastic, and get warped if the head is overheated (by you or previous owner(s)). Cracking is common too.
Replacing the seal won't help if you're trying to solve a leak at that point.
Reply #2October 21, 2008, 07:50:32 am
« Reply #2 on: October 21, 2008, 07:50:32 am »
Plastic ones are O Rings no?
mine is at least.
