Author Topic: Finally got my Guide  (Read 2953 times)
October 14, 2008, 05:25:07 pm
VW_Commuter
  • 355
« on: October 14, 2008, 05:25:07 pm »
My Jetta has the dreaded worn crankshaft nose keyway and a friend of mine was making me a drillguide to put 4 3/16" dowel pins in to try and not have to replace the crankshaft.  Well, it's finally done and here are some pics:
I've already picked up the dowel pins and I need to find a bolt that's long enough to pass through the drill guide, the timing gear, engage the crankshaft with enough threads to prevent stripping or movement during drilling, and also with a small enough head so I can drill the holes in the crank.  I also need to get a new crankshaft bolt (either the grade 10.9 bolt like Jet A did or the OEM bolt from the dealer, haven't decided yet).
I'll probably tackle this job this weekend after I go up north of Seattle to pick up the rear license plate filler panels for my Jetta.  I'll also post pics taken during the drilling process.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #1October 14, 2008, 08:04:14 pm
blkboostedtruck
  • 1535
« Reply #1 on: October 14, 2008, 08:04:14 pm »
ahh that nice! is he in the mood to make me one? i'll pay for it!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2October 14, 2008, 09:43:42 pm
VW_Commuter
  • 355
« Reply #2 on: October 14, 2008, 09:43:42 pm »
Duane, I had asked him what it would cost to make another one and he said the man-hours that it took to machine the guide and the cost of the stock would put the price at around $300 to $400 due to the fact that all of the machine work would has to be done manually.  He did it for me as a favor and I owe him big time for it.
I have the Parasolid CAD File (also known as a Modeller Transmit File) so that a drill guide jig can be made on a CNC machine if you would like me to send it to you.  I was quoted between $200 to $250, which included materials, to have a machine shop make one on their CNC.
Greg
Reply #3October 14, 2008, 09:52:50 pm
blkboostedtruck
  • 1535
« Reply #3 on: October 14, 2008, 09:52:50 pm »
wow you got a great friend !
i'll talk to my partner and see what he want to do?
thanks Duane
'66 variant 1500S
Reply #4October 15, 2008, 07:15:24 am
« Reply #4 on: October 15, 2008, 07:15:24 am »
Did you guys see this? http://www.vwdiesel.net/phpBB/viewtopic.php?t=13828&highlight=
Gotta be cheaper than that.  I can vouch for the guy's reputation too, he built a bomb-proof front crossmember brace for my Scirocco.
Reply #5October 15, 2008, 08:33:42 am
VW_Commuter
  • 355
« Reply #5 on: October 15, 2008, 08:33:42 am »
GoKraut is the one who emailed me the CNC file.  The $200 was what I was quoted by a local machine shop here in Renton, WA to have them machine me the part and included all materials.  The price of $300 to $400 was what my friend said it would cost for them to buy the bar stock, drill bits, and the man-hours involved in manually machining the part since he didn't have a CNC milling machine.
I'm sure you can find a machine shop locally that can handle the template file and make the part on the CNC mill.  I think my friend made the part for me as a favor and also because he considered it a challenge to try and make it, he's just that kind of person.
Greg
Reply #6October 15, 2008, 03:12:31 pm
« Reply #6 on: October 15, 2008, 03:12:31 pm »
aside from it being hardened i don't see what is so expensive?  its a round piece of metal with 7 holes in it?
