Author Topic: What oil do i use?  (Read 7713 times)
October 09, 2008, 04:09:43 pm
duff
  • 18
What oil do i use?
« on: October 09, 2008, 04:09:43 pm »
hey i just rebuilt a 1.6 TD out of an 80 something jetta and i was wondering what oil does it take. i know diesels take a special oil but what weight and what runs best in these IDI's
Reply #1October 09, 2008, 04:29:03 pm
rallydiesel
  • 1880
What oil do i use?
« Reply #1 on: October 09, 2008, 04:29:03 pm »
Well, since it's just rebuilt I'd go with a regular diesel motor oil. The grade depends on how cold your winters are. After the engine is broken in I use Rotella 0w40 synthetic.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2October 09, 2008, 04:37:59 pm
blkboostedtruck
  • 1535
What oil do i use?
« Reply #2 on: October 09, 2008, 04:37:59 pm »
atleast get 2 oil changes in before switching to synthetic oil!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3October 09, 2008, 07:20:40 pm
duff
  • 18
What oil do i use?
« Reply #3 on: October 09, 2008, 07:20:40 pm »
hey thanks for the help. i live in Texas where it gets down to a freezing 65 degrees two months out of the year. so what grade would you recommend, 15w-40??
Reply #4October 09, 2008, 07:29:19 pm
What oil do i use?
« Reply #4 on: October 09, 2008, 07:29:19 pm »
I live in central Alaska and run delo 400 15w-40 year round, I have a block heater and 150W of oil pan heaters though. I wouldn't run very thin oil in Texas.
Reply #5October 09, 2008, 09:02:28 pm
What oil do i use?
« Reply #5 on: October 09, 2008, 09:02:28 pm »
if you installed new rings, then dont use synthetic as stated above.  you should even give it a good 10'000km's to seat the rings...  then switch on over to synthetic for the life of the motor and it should last a good long time.
make sure the diesel oil is rated CF (CD is the old standard for turbodiesels)
Reply #6October 09, 2008, 09:34:03 pm
Dakotakid
  • 1240
What oil do i use?
« Reply #6 on: October 09, 2008, 09:34:03 pm »
Just tonight, I was in Walmart and was going to get a 2.5 gallon container of 15/40 Rotella. Then I saw the price on 15/40 Motorcraft CJ rated oil. It was $10.68 for 5 quarts. The Rotella was an even $26.00 for 2.5 gallons.
I decided to put my "usual" back on the shelf and go with several containers of the Ford Motorcraft. I believe it is probably good oil...better price right at the moment. This would suit you well.
Reply #7October 10, 2008, 07:08:52 am
arb
What oil do i use?
« Reply #7 on: October 10, 2008, 07:08:52 am »
Like everyone said, if you did your rings, use regular oil with a CF rating - like a 10w-40 for your first 2 oil changes - about 10K km. Then go with a full synthetic. You could start with full synthetic like Mobil One, but if you have fresh rings they will take for ever to seat and you'll be burning quite a bit of motor oil for your first 50k km - maybe a quart every 2k km. - Been there, done that - expensive lesson.
Reply #8October 10, 2008, 07:17:08 am
saurkraut
  • 904
What oil do i use?
« Reply #8 on: October 10, 2008, 07:17:08 am »
I think in the"C" rated oil, the -4 rating is for 4 stroke applications.  The current -4 rating is CI-4.  Rotella 15W40 would be a good choice.
API Oil Guide
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #9October 10, 2008, 10:38:23 am
blkboostedtruck
  • 1535
What oil do i use?
« Reply #9 on: October 10, 2008, 10:38:23 am »
Quote from: "saurkraut"
API Oil Guide
Tyler should add that oil guide to the FAQ section that he's doing!
Duane
'66 variant 1500S
Reply #10October 10, 2008, 11:08:06 am
79rabbit4dr
What oil do i use?
« Reply #10 on: October 10, 2008, 11:08:06 am »
I know there are certain break-in additives you want in your oil on gas cars, i'm not sure for diesels. There was a special lube I had to put on my new cam for break-in as well.
Also, what all was done? What oiled parts are new?
Reply #11October 10, 2008, 11:55:15 am
arb
What oil do i use?
« Reply #11 on: October 10, 2008, 11:55:15 am »
Quote from: "79rabbit4dr"
I know there are certain break-in additives you want in your oil on gas cars, I'm not sure for diesels. There was a special lube I had to put on my new cam for break-in as well.
The cam lube for a new cam is because it is under a very high psi and will be mostly dry on initial startup.
The CD-4 rating was among other things for soot suspension. Mobil 1 does not have this and this is why it can't be used long term in a PowerStroke diesel - their injectors are powered by engine oil pressure and fired via a 110v solenoid. This long device has close tolerances that become plugged with soot if the oil doesn't have CD-4 Mobil's industrial synthetic oil - Delvac 1 has this CD-4 rating.
Reply #12October 10, 2008, 11:58:00 am
What oil do i use?
« Reply #12 on: October 10, 2008, 11:58:00 am »
Ok so CD-4 is a good oil then.. Check..
Reply #13October 10, 2008, 11:59:59 am
saurkraut
  • 904
What oil do i use?
« Reply #13 on: October 10, 2008, 11:59:59 am »
Quote from: "arb"
Delvac 1 has this CI-4 rating.
Fixed it for yah
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #14October 10, 2008, 07:18:04 pm
kane66
  • 131
What oil do i use?
« Reply #14 on: October 10, 2008, 07:18:04 pm »
does anyone use the amsoil 5w40, they guarantee 25000 miles in a diesel. expensive up front but cheaper in the long run, also what oil filter do people recommend
1985 Jetta WBE
