Author Topic: injectors  (Read 2002 times)
November 29, 2008, 10:42:06 am
96jetta
injectors
« on: November 29, 2008, 10:42:06 am »
what are the injectors on a 1996 1.9td torqued to?
Reply #1November 30, 2008, 09:38:20 am
injectors
« Reply #1 on: November 30, 2008, 09:38:20 am »
I think 55 ft-lbs like the 1.6...
Reply #2November 30, 2008, 01:05:02 pm
Typrus
  • 93
injectors
« Reply #2 on: November 30, 2008, 01:05:02 pm »
96 Should be a TDI I thought? Or am I in need of some edjumacation?
The claw that holds the injectors down is something like 30-35ft/lb if I remember right? The bolts like to stretch quite a bit though, and after one or two cycles can actually stretch enough to keep the claw from getting tight (the bolt just bottoms out) you can use washers to help, but new bolts would be the better plan.
1995 Toyota Camry 2.2L 5-speed
1984 Toyota Tercel 4wd Wagon 1986 "           "           "      "
1996 VW Passat TDI 1Z w/ KermaTDI Stage 3 kit
1999.5 F-250 7.3L Powerstroke
2002 Excursion 7.3L Powerstroke (Dads)
