i'm guessing this is going to be terminal?
Topic: i'm guessing this is going to be terminal? (Read 2363 times)
November 19, 2008, 01:19:55 pm
MouseGTD
November 19, 2008, 01:19:55 pm »
the story starts a week ago we i was pulling in to my mates street in my 1.6td and it just looses all power, even at full throttle it was like it was ticking over then when i let off it died. i checked under the hood and could see nothing amiss, tried restarting it and with quick a bit of cranking and keeping my foot to the floor it started to fire then chugged into life, kept foot to floor and it cleared and ran fine again with no problems.
then last night it did it once again but drove home fine, drove to and from work today fine, then i set off to the shop, it did it twice on the way there then on the way back did it every time i slowed or came to a stop. as i could find nothing wrong with it before i didn't bother checking it, just tried to get the short distance home. when i got home i looked under it to find a massive puddle of oil, jacked it up for a better look to find oil covering every thing from the back of the engine to the rear of the car, this was the course of it...
the pipe that goes to the turbo had come off firing all the oil every where, now i know i'm gonna of probably damaged it trying to drive it with no oil but is there any chance that its not totally fubar? once i'd put the pipe back on i left it a little while and tried to start it and it fired up and revved fine, but i had to turn it straight off due to having no oil in it.
November 19, 2008, 01:42:58 pm
November 19, 2008, 01:42:58 pm »
Can we have a moment of silence for a fried engine please? Bows head.
November 19, 2008, 02:05:24 pm
MouseGTD
November 19, 2008, 02:05:24 pm »
i take it its dead then? lol
how do the 1.9td AAZ lumps compare? i've found what seems to be a full 1.9td set up for sale if this one is dead.
November 19, 2008, 02:10:54 pm
blkboostedtruck
November 19, 2008, 02:10:54 pm »
fix the return line! add oil and see what happens?
it could not hurt? you all ready know you might need a rebuild?
it might just last for a while?
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
November 19, 2008, 02:40:02 pm
November 19, 2008, 02:40:02 pm »
That's what I would do. I'll bet the cam towers are damaged as well as the bearings but like Duane said what do ya have to loose?
November 20, 2008, 06:22:53 am
arb
November 20, 2008, 06:22:53 am »
It you had check the oil the first time it died, I'll bet you could have been fine. I something similar happen to one of my 1.6L NA when a cheap filter burst. Didn't try to start w/o oil. Replaced the filter with a quality one and filled the pan = Ran another 100 k Miles w/o issue.
But, yours has been started and ran repeatedly w/o oil. Pull the valve cover and look at your cam lobes and followers. These will die before the engine bearings when staved of oil (usually) - I bet they are gulled.
Its only 8 nuts - 10mm socket - to pull it.
November 20, 2008, 12:26:24 pm
MouseGTD
November 20, 2008, 12:26:24 pm »
next time my car 'breaks down' i guess i should check how much fuels in it :oops:
it was loosing power cutting out and taking ages to start again due to the tank being empty, and from the trail of oil i followed earlier the oil pipe must of only came off up the road from my house and judging by the amount of oil it took to get it to register on the dip stick there must of still been a fair amount in the engine, obviusly not enough to show on the dip stick but still enough to stop it causing massive damage when i started it. i guess my fuel gauge works better than i thought it did.
November 20, 2008, 01:02:41 pm
Dirtrag2
November 20, 2008, 01:02:41 pm »
if it rund ok change the oil and fill it with Amsoil diesel oil :!: the amsoil won't break down and might just keep you running for longer
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
November 20, 2008, 04:22:23 pm
Jet A
November 20, 2008, 04:22:23 pm »
Pull the valve cover and have a look at the cam towers and tops of the lifter buckets. looks for signs of heat or wear. If those are good, maybe you got lucky and didnt drive it completly out of oil, just mostly....
85 vw golf NA ----> 2b TD Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
