Author Topic: Boost controller questions  (Read 2308 times)
November 19, 2008, 04:12:11 pm
starrd
  • 128
« on: November 19, 2008, 04:12:11 pm »
Just about there with my build and I have a few questions:
1) What boost controller are you guys using on a K14 - AAZ?
2) do you just cut the metal line going to the wastegate?
3) with a boost controller, do you still have to adjust the wastegate on a K14 to get 18 psi?
4) what timing are you running with a Giles pump? - I set to 1mm, but should it be less?
Just want to make sure I do this right, thanks for any input.
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #1November 20, 2008, 07:38:59 am
Luckypabst
  • 502
« Reply #1 on: November 20, 2008, 07:38:59 am »
I bought a boost controller off Ebay and can't remember right now what it was called but it was pretty affordable. I simply cut the metal line and installed the boost controller inline.
After running it for a few trips I screwed the wastegate screw all the way in to effectively lock out it's actuation and now top out at 18 psi all day long - no boost controller needed. I think removing the metal line and plugging the holes will give you the same results.
Chris
'82 TD Westy
'81 NA Caddy
Reply #2November 20, 2008, 02:02:19 pm
monomer
  • 414
« Reply #2 on: November 20, 2008, 02:02:19 pm »
a simple bleed-type controller can be made with parts from home depo/lowes.
google it.
www.michiganvw.org
Reply #3November 20, 2008, 05:05:53 pm
beew
  • 27
« Reply #3 on: November 20, 2008, 05:05:53 pm »
basically all you need isa relief valve set to your max boost pressure.. you would also need a bleeder hole so the wastegate can return to the closed position.
google "grainger valve"
94 Jetta GL diesel
