Author Topic: Inside of the turbo intake log manifolds  (Read 3445 times)
November 22, 2008, 11:24:13 am
« on: November 22, 2008, 11:24:13 am »
*edit* What is involved in making a log manifold for your 1.6L TD?
Well I was thinking of making from scracth or hacking up mine and welding some onto it. What I really need to know is what do I have to know about the internal design. Is it restricted inside those things or like a dual plane some kind of thing. Or what I am hoping for is that it is just a gaint opening for all the air to dump into the engine. If anyone has a picture that would help greatly. I need to know what I am getting into before I make my mess :D
Reply #1November 22, 2008, 02:30:13 pm
SR Heer
  • 199
« Reply #1 on: November 22, 2008, 02:30:13 pm »
OK - you win
For those of me who do not know what you are trying to accomplish,
Can you be more descriptive?
Thanks
Steve
Reply #2November 22, 2008, 06:07:45 pm
monomer
  • 414
« Reply #2 on: November 22, 2008, 06:07:45 pm »
look at the passenger performance one.
It's a standard 1.6td intake manifold, chopped square right above all the ports.  long sections of alumn is capped off with a notched-out pipe (of the IC plumbings dia.)
They call them a ram's Horn intake (or something like that)
www.michiganvw.org
Reply #3November 22, 2008, 06:16:41 pm
« Reply #3 on: November 22, 2008, 06:16:41 pm »
Yeah I have looked there. I just didn't know if there was any kind of inside porting or if it was like a dual plane where the air came in went to the back and then turned before dumping into the intakes. If it isn't like that then I will probably have some fun and start welding.
Reply #4November 23, 2008, 01:19:55 am
carrizog60
  • 978
« Reply #4 on: November 23, 2008, 01:19:55 am »
whats the big improvemet over the stock one?
and why the stock one is bad?
is it design?
if someone could explain that i would like to know...
for a start i think if you want to improve something you have to know how does it work first.
and i dont know :lol:
Portugal
Reply #5November 23, 2008, 06:07:20 am
dillenger1
  • 777
« Reply #5 on: November 23, 2008, 06:07:20 am »
flow restriction!the larger intake allows more air,therefore more air can get pushed in on each compression stroke.Ive heard gains of 10hp with only the mahifold.The stock intake ports are only around 1 1/2",opening that up well allow flow.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #6November 23, 2008, 08:14:00 am
dillenger1
  • 777
« Reply #6 on: November 23, 2008, 08:14:00 am »
I would think a driverside inlet would favor cylinders 3 and 4
Reply #7November 23, 2008, 08:17:09 am
AudiVWguy
« Reply #7 on: November 23, 2008, 08:17:09 am »
What's the word on the Corrado G60 style manifold? Any down sides?
Reply #8November 23, 2008, 02:25:28 pm
dillenger1
  • 777
« Reply #8 on: November 23, 2008, 02:25:28 pm »
youll need to flip the exhaust manifold and clock the turbo or make a spacer.
Reply #9November 23, 2008, 02:28:04 pm
carrizog60
  • 978
« Reply #9 on: November 23, 2008, 02:28:04 pm »
Quote from: "dillenger1"
not a expert or closed to that but i also have this idea... :idea:
Portugal
Reply #10November 24, 2008, 08:08:15 am
« Reply #10 on: November 24, 2008, 08:08:15 am »
Quote from: "carrizog60"
I don't believe that would be the case in a turbo application. In NA mode ya I could see it as each cyl is sucking it's inlet charge but in a forced induction situation the turbo is charging the entire "log" at the same time. The air will be pushed into what ever cyl has a open intake valve.
With our OE intake manifolds there is no common area for the turbo to charge and 2/3 intakes are right below the intake horn so the get the benefit of direct forced induction while 1 and 4 get what's left over.
