Electrical supercharger
Topic: Electrical supercharger (Read 5858 times)
November 19, 2008, 01:01:59 am
blueattack
Newbie
November 19, 2008, 01:01:59 am »
Has someone tried these before ?
I wanted to add one to my 1.9td aaz (it has a K24 turbo), just to get some more boost at low rpm,
can it hurt my engine ?
There are kits on ebay in the USA for about 25 dollars and here in Europe they cost around 150 dollars , what the difference or is it just the price ?
November 19, 2008, 01:27:03 am
November 19, 2008, 01:27:03 am »
Those electric super chargers always seem too good to be true.
Can they really make good CFM at decent pressure?
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
November 19, 2008, 01:46:09 am
Turbinepowered
November 19, 2008, 01:46:09 am »
Most of the cheapo "electric superchargers" are
scams
. It takes a strong motor to produce decent boost pressure at the flow rates engines need, and strong motors draw a lot of electrical power.
November 19, 2008, 02:14:07 am
maxfax
November 19, 2008, 02:14:07 am »
These actually rob you of power most of the time.. They act as a restriction and can cause some odd turbulance (the turbulance doesn;t really affect a diesel too much though)... Like Turbine said takes a strong high RPM motor and a pretty big fan to move enough air to even equal what your engine would require without the turbo...
Just about all of these are the equivelent to the fan on your heater, some might rate up there with a leaf blower....
November 19, 2008, 02:41:31 am
clbanman
Cambridge, Ontario
November 19, 2008, 02:41:31 am »
I'll bet if you bought one and put a balloon over the outlet it would have a hard time popping the balloon. Something cheaper than your heater blower motor is supposed to pressurize your intake?
Calvin
91 VW Golf 1.6NA 5spd
November 19, 2008, 03:52:32 am
maxfax
November 19, 2008, 03:52:32 am »
I doubt they could inflate a balloon since the elasticity of the rubber could pressurize the air more than the fan... These things actually originated as an auxilary blower for automotive HVAC use..
November 19, 2008, 08:08:29 am
Duster 5.9
November 19, 2008, 08:08:29 am »
may work on a lawnmower.
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
November 19, 2008, 08:38:33 am
blkboostedtruck
November 19, 2008, 08:38:33 am »
or one of these?
i would need a battery and bracket to hold the battery
it just seems like it would be more hassle then gain?
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
November 19, 2008, 08:53:11 am
November 19, 2008, 08:53:11 am »
Get one and do it Duane.
November 19, 2008, 09:04:09 am
blkboostedtruck
November 19, 2008, 09:04:09 am »
i'd rather stick a K03 on it! then mess with all that electrical stuff!
you know me i hate electrical stuff!
Duane
'66 variant 1500S
November 19, 2008, 10:15:23 am
allsierra123
November 19, 2008, 10:15:23 am »
Its not really hard to slap a turbo on a a N/A diesel. And you will get an actual increase in power.
Reply #11
November 19, 2008, 11:16:36 am
arb
Reply #11 on:
November 19, 2008, 11:16:36 am »
Yeah, these are a real scam... Some guys have made real electric superchargers, but they use a remendous amoount of electic power and it has to come from some place.... Here's on that suceeded. Notice it has 3 LARGE custom built motors to power it.
http://www.turbomagazine.com/tech/0406tur_knight_turbo_electric_supercharger/index.html
Reply #12
November 19, 2008, 11:25:49 am
allsierra123
Reply #12 on:
November 19, 2008, 11:25:49 am »
:shock: wow all I can sow is wow. I have always thought the science of it was sound but never expected that.
Reply #13
November 19, 2008, 11:32:22 am
Reply #13 on:
November 19, 2008, 11:32:22 am »
sweet jesus.
The ebay seller's store page looks like a joke after seeing that.
THROWN ROD
Reply #14
November 19, 2008, 11:51:37 am
arb
Reply #14 on:
November 19, 2008, 11:51:37 am »
Yeah, notice the small gauge wire on that cheep "blower" - what ? 12g ? So you're looking at maybe 30 amps ( 420w @ 14v). Your 1.9L engine needs just over 100 CFM at 3000 rpm. Look at the HP requirement for a 100 CFM compressor even at only 15 psi. Quite a bit more than a 420 watt motor can do for you.
